Lenovo THINKPAD T470S NM B081 REV1 DEAD
  • Yosua
    • Jun 2021
    • 221
    • Indonesia
    hi friends, here I want to ask for your help, because currently I am working on a Lenovo Thinkpad T470s with the nm code b081 rev 1, the case is the first time it is turned on when the charging cable is inserted it can turn on but can turn off for a few minutes and when the power button is pressed it can no longer turn on as before, but when the charging cable is removed and inserted again, it can turn on again but turns off again
    on the dcin path I have measured PQ1 and PQ2
    when in normal conditions they appear 19v on the source and drain then the gate appears 9v
    but when the condition suddenly turns off, PQ1 has 19v on the source and so does the gate appears 19v.
    I hope some friends can help me, thank you​
  • questore
    • Dec 2015
    • 573
    • csongrád
    Hi, welcome,
    Measure Gate tó source resistance ön PQ1
    • Yosua
      • Jun 2021
      • 221
      • Indonesia
      Thank you for taking the time, the result of the diode mode measurement is 1.446
      • questore
        • Dec 2015
        • 573
        • csongrád
        Measure it in resistance mode. and post the result
        • Yosua
          • Jun 2021
          • 221
          • Indonesia
          The result is 199k ohms when the black probe is on the gate and the red on the source and 91k ohms when the probes are swapped.
          • questore
            • Dec 2015
            • 573
            • csongrád
            At first when you can turn on the laptop is it showing and display?
            • questore
              • Dec 2015
              • 573
              • csongrád
              when you got 19v on gate and then remove power what resistance you got here?
              • Yosua
                • Jun 2021
                • 221
                • Indonesia
                When the laptop is on, everything runs well and the screen can display images.
                • Yosua
                  • Jun 2021
                  • 221
                  • Indonesia
                  This is the measurement result when the laptop is off and my charger is removed, sir.
                  • questore
                    • Dec 2015
                    • 573
                    • csongrád
                    Do the laptop turn off by itself after XX minutes?
                    • Yosua
                      • Jun 2021
                      • 221
                      • Indonesia
                      True, but it can't be determined how long it can turn on, sometimes it can enter windows, but when the machine feels warm, it can only reach the windows logo and then turns itself off.
                      then when the condition is off but the charger is still attached to the PQ1 SOURCE & GATE, 19v appears, after that I tried to unplug and reinstall the charger then all fets (PQ1 & PQ2) have normal voltage, SOURCE & DRAIN: 19V, GATE: 9V​
                      • questore
                        • Dec 2015
                        • 573
                        • csongrád
                        Could be an overheating protection. I would check the heatsink if it is contacting the cpu and GPU properly.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          All symptoms so far indicates problem in charging circuit as +19V rail suddenly cuts off. Right?
                          I'll bet for two things only
                          01.A burnt resistor on BTST pin of charging IC.
                          02.Missing connectivity on ACN/ACP to CLR or CSN/CSP to CLR
                          • Yosua
                            • Jun 2021
                            • 221
                            • Indonesia
                            for now the development is, when my 3v&5v coils are broken, the 19v line is safe, does this mean the TPS5128 IC is damaged or weak?
                            • Yosua
                              • Jun 2021
                              • 221
                              • Indonesia
                              Thank you friend, but the processor heatsink and cooling paste are still safe
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Answer post#13 first.
                                We cant advise without proper feedback.
                                  Lenovo ThinkPad T470s Notebook T Specification for Upgrade or Repair
                                  This specification for the Lenovo ThinkPad T470s Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T470s boardview and T470s schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                                  09-06-2024, 11:30 AM
                                  09-06-2024, 11:29 AM
                                  09-06-2024, 09:00 AM
