Lenovo Ideapad Gaming 3 15ACH6 doesn't charge
  • AleX.dans.les.nuages
    • Apr 2025
    • 7
    • France
    Hello from France
    My daughter spill some water on her laptop... Lenovo Ideapad Gaming 3 15ACH6, and she doesn't seen anything wrong after just remove the water with towel.
    Then, later the laptop won't start anymore.
    I've made a basic troubleshoot with my own laptop (same series)
    So, the computer battery is totaly out. With my battery, the computer works !
    But, with PSU connected, the latptop detect the power.. the harware led white is on, the amber one too and on the screen there is a 'batt charging' message.
    But there is absolutly no charge to the battery. (And the laptop doesn't goes to auto off, and kill the battery)
    So, I've found the wiring on this message (thanks Lisa Su) and here (thanks to AL._.EX )
    I've made some basic checks, and then, found the following :
    The +19V_VIN is OK (20.1 volts)
    On the point 'A' (PD303 cathodes), with no PSU, the batt voltage is present, and with PSU, the 20 volts is present.
    On the point 'B', there is always the batt voltage.
    And then for all the following, same thing :
    ACDRV-1 (PQ303/PQ310 gate), 0V with batt, and 2.8V with PSU connected
    ACDRV-2 (PQ301/PQ309 gate), 0V with batt, and 2.8V with PSU connected
    CMSRC-1 (between source and drain of the mosfets), 0V with batt, and 2.8V with PSU connected
    I'm not able to do the check on the pads 3(CMSRC) or 4(ACDRV) of the BQ24800 (datasheet https://www.ti.com/lit/ds/symlink/bq24800.pdf) and I can't locate the resistors.
    But so, I think the BQ24800 is OK
    Could you confirm PQ307 is a 'gate' between ACDRV and CMSRC command ?
    Do you think that the problem root cause can be the mosfet PQ301/PQ303/PQ309/PQ310 ? Or can I check something else... ?
  • mon2
    • Dec 2019
    • 14681
    Hello and welcome. Yes, PQ301 / PQ303 are suspects. A must read is the sticky article on charger circuits above by piernov. He is also in France and we are hoping for his onsite (international) service but so far no go.
    Remove all power. Meter in resistance mode. Measure each of the referenced DCin mosfets using resistance mode of testing.
    Measure:
    source (1-2-3) & drain (5-6-7-8)
    source (1-2-3) & gate (4)
    gate (4) & drain (5-6-7-8)
    Each measurement should be hundreds of k ohms or higher else the mosfet may be defective and leaking. Review PQ303 and then PQ301. Since they both are driven by the common gate signal, it is possible that one defective mosfet can make both look bad. Often, the 2nd DCin mosfet is the defective one but suggest to test both.
    Do you also have PQ309 / PQ310 onboard? To me it appears that either one pair of mosfets OR the other pair are being stuffed on this logic board.
      • Apr 2025
      • 7
      • France
      Yep, on this MB, there is 2 couples of mosfet
      PQ301 and PQ309 : AON6426 (30V / 65A)
      PQ303 and PQ310 : EMB12N03H (30V / 25A)
      I've already seen (quickly) the sticked subject, but the chapter '2.2 battery not charging' is not really applicable... BTW, in the previous chapter, 2.1.3 something is really near my own case..
      And so, I think you give me the good next step !!
      Without battery and with no power supply, (with a very cheap multimeter) I get :
      for PQ303/310 (+19V_VIN side)
      gate (4) to source (1-2-3) : 6 ohms (same thing with reversed polarity)
      drain (5-6-7-8) to source (1-2-3) : around 120 Kohms
      source (1-2-3) to drain (5-6-7-8) : around 60 Kohms
      drain (5-6-7-8) to gate (4) : around 120 Kohms
      gate (4) to drain (5-6-7-8) : around 60 Kohms
      for PQ301/309 (P3 or 'VBAT' side)
      gate (4) to source (1-2-3) : 1 ohms (same thing with reversed polarity)
      drain (5-6-7-8) to source (1-2-3) : above 1.5 Megohms
      source (1-2-3) to drain( 5-6-7-8) : around 60 Kohms
      drain( 5-6-7-8) to gate(4) : above 1.5 Megohms
      gate(4) to drain( 5-6-7-8) : around 60 Kohms
      Just one word from you, and I'll order it ! (probably 10 of each..)
      • mon2
        • Dec 2019
        • 14681
        Good. The gate / source measurements are much too low to be a good thing for both pairs. The best solution is to consider to repace each of these 4 mosfets, they should be inexpensive on Aliexpress. Just select a good vendor with a high rating. If you are in a rush, confident that we can find something suitable from Mouser / Digikey with higher costs but much faster delivery. If you select the 'rush' options from Aliexpress, I know that we are receiving goods in ~2 weeks here in Canada so suspecting that your delivery will be much faster.
        Even the gate/drain measurements @ 60k ohms are too low for a good mosfet but these measurements may not be accurate due to the very shorted gate / source values.
        You could even order a spare charger IC but that may be ok since the unit is working with the battery. Aliexpress has it all. Just be sure to order the exact part as noted in the schematics.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Its best to remove the concerned mosfets from PCB and then check them out of circuit. The low readings may be from PCB .
            • Apr 2025
            • 7
            • France
            Parts ordered.. At ACoLab (local FabLab), there is an hot air station to replace it. (And to check mosfet out of the PCB mcplslg123 )
              Lenovo Legion S7 15ACH6 Notebook Specification for Upgrade or Repair
              This specification for the Lenovo Legion S7 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S7 15ACH6 boardview and S7 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
              09-07-2024, 05:00 AM
              Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
              Lenovo IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
              This specification for the Lenovo IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Gaming 3 15ACH6 boardview and Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
              09-07-2024, 04:30 AM
              Lenovo Legion 5 15ACH6 Notebook Specification for Upgrade or Repair
              This specification for the Lenovo Legion 5 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5 15ACH6 boardview and 5 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
