hp elitebook 840 g3 not turning on
  • Linksman
    • Jul 2022
    • 34
    • Zimbabwe
    hello guys l have an hp elitebook 840 g3 board number 6050A2892401 MB A01 it's not turning on checked first moseft 19v is present but on the current sensor am getting 4.2v l tried to changed the first moseft but am still getting 4.2v on the current sensor.
    I tried to trigger the first moseft drain and source pins using a twizzer when l checked on the current sensor 19v was now present ,the moment l removed the twizzer on drain and source voltage drops to 4.2v
    what could be the issue
  • mon2
    • Dec 2019
    • 14231
    Is there 2nd dcin mosfet that shares the same gate voltage? Replace it and test again.
    Review the charger sticky above by piernov.
    • Linksman
      • Jul 2022
      • 34
      • Zimbabwe
      it's there l replaced it but the problem is it's the same
      • mon2
        • Dec 2019
        • 14231
        Which charger chip is onboard? BQ series by TI?
        Share the voltage measurements for:
        REGN
        ACOK
        ACDET
        VCC
        • Linksman
          • Jul 2022
          • 34
          • Zimbabwe
          REGN
          ACOK
          ACDET
          VCC
          Here are the voltage measurements
          REGN......0.4v ACOK.......0v
          ACDET.....2.7v
          VCC........ 4.2v
          • mon2
            • Dec 2019
            • 14231
            VCC........ 4.2v
            Is too low. Confirm the charger IC onboard (BQ24780S?) and the pin you are measuring.
            Locate on this same pin, there should be a dual diode (sot23 package). Measure the voltage to ground on each of the pins on this dual diode. Unable to find schematics for this board but believe you have a BQ24780S onboard for the charger IC? If yes, the VCC pin is pin # 28.
            Something is wrong here.
            • Linksman
              • Jul 2022
              • 34
              • Zimbabwe
              the charger ic onboard is BQ24780S you are right
              VCC pin is number #28 Checked voltage again it's 19v
              • mon2
                • Dec 2019
                • 14231
                So earlier VCC measurement was a mistake or did VCC change? This is important.
                Also, what is REGN now? It should be ~6v. If it is not, carefully locate a series resistor of a value of ~4k ohms on ACDRV.
                What is the voltage here? It should be ~25v if all is OK = adapter voltage + REGN voltage = 19v + 6v = 25v.
                Next, remove all power, meter in resistance mode. Measure the resistance to ground on REGN.
                The details shared so far may indicate that this charger IC is defective as REGN should be 6v as long as the VCC is stable @ ~19v.
                • Linksman
                  • Jul 2022
                  • 34
                  • Zimbabwe
                  measurement was a mistake l was using a wrong schematic lol.
                  REGN AND ACDRV are pinj number what on charger ic l don't have a schematic
                  • mon2
                    • Dec 2019
                    • 14231
                    You can download a full datasheet for this same charger IC from Texas Instruments. Use that to view the pin # and post an updated list.
                    Important to know that REGN is ~6v.
                    https://www.ti.com/lit/gpn/bq24780s
                    • Linksman
                      • Jul 2022
                      • 34
                      • Zimbabwe
                      thank you let me do that and give you feedback
                      • Linksman
                        • Jul 2022
                        • 34
                        • Zimbabwe
                        REGN is 6V
                        REGN resistance measurements to ground it's 1.11
                        • lapfix
                          • Mar 2020
                          • 2730
                          • my workshop
                          Maybe it help
                          • mon2
                            • Dec 2019
                            • 14231
                            Thanks lapfix!
                            Linksman, always share the units of measurement. For resistance, it will be in ohms but suspecting it is kohms since the voltage is correct @ 6v.
                            Share the meter scale for all measurements.
                            What is the voltage on ACDRV? This is the same as the gate voltage and should be low on your board since the mosfets are not enabling.
                            • lapfix
                              • Mar 2020
                              • 2730
                              • my workshop
                              Image With Coil Volatage and Impedance
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Why are we troubeshooting charging IC when all major rails are coming up except Vcore.
                                Its time to check core IC requirements and flashing a clean me tested good bios.
                                • lapfix
                                  • Mar 2020
                                  • 2730
                                  • my workshop
                                  Hello mcplslg
                                  The pictures i posted at post 15 is just to indicate the place of taking mesaurements , it's not the issue of this topic
                                  • Linksman
                                    • Jul 2022
                                    • 34
                                    • Zimbabwe
                                    Thanks lapfix!
                                    ACDRV Measurement it's 0v
                                    • Linksman
                                      • Jul 2022
                                      • 34
                                      • Zimbabwe
                                      thank you lapfix
                                        HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:50 AM
                                        HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                        This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                        09-07-2024, 05:20 AM
