asus vivobook X1052Z not charging
  • Patriarxis
    • 19
    • Greece
    Hello
    At an Asus vivobook x1052z battery not chargig .
    at the battery connector i have 19V and the charging light is always on.
    Any ideas what to check?
  • mon2
    • 14657
    Be sure that the power adapter is the proper one for this laptop. This is important else charging will stop and the CPU speed will be throttled. Asus schematics are rare so you will have to hunt for the charger IC that is onboard. Most likely will be the 'BQ' or 'ISL' series of charger chips. Share full details on what you find. From this knowledge, you can compare the reference design schematics to understand what is onboard.
    Also be sure that the fault is not with the battery itself. Test with another known good battery.
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
    • cope
      Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
      by cope
      I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
      Some history:
      Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
      As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
      Now, with a new battery the system will start up and run off...
      05-13-2024, 09:40 AM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
