Dell 5420 motherboard help
  • burtDell
    • Feb 2025
    • 5
    Hey all
    I was replacing my screen on my 5420 and dropped the display connector metal cover piece for a second on the board and a capacitor(?) sparked for a sec
    I just want to see what I damaged and how to fix it
    GDF40 LA-K419P Rev 2​
    Click image for larger version  Name:	IMG_0182.jpg Views:	0 Size:	1,019.7 KB ID:	3562826
  • mon2
    • Dec 2019
    • 14660
    See attached. Is the board no longer working? Measure the voltage to ground on each side of this ferrite bead. You should measure ~18 volts on each side of this component. This part is present to filter noise on the backlight power supply. Component is a low cost ferrite bead which will under $1 USD in small qty (under $0.10 USD in volume). Digikey / Mouser / Arrow electronics will offer replacements but this part is not critical to be present onboard. The accident may have caused the main power supply to become defective.
    Of a larger concern is that the laptop was powered while replacing the screen?? If yes, many other faults may surface.
    ALWAYS, remove the power (adapter & battery) before reviewing or replacing parts unless told otherwise for voltage measurements. Otherwise, you are working with an 'electrically hot' board which is extremely risky.
    • burtDell
      • Feb 2025
      • 5
      Thank you for that info. I should have added to my original post that the laptop still powers on and I am able to use it without any issues (that I can tell).
      No the battery was removed during the replacement. I just didnt know if the replacement screen would work as I scavenged it from my parts bin. Thats why I left that display cover off, powered the machine on, got excited that the screen worked and went to put the cover back on and fumbled the piece. Rookie move for sure.
      • mon2
        • Dec 2019
        • 14660
        I think you have dodged a bullet. The spark was just that only. This part is like an electronic resistor. The part will be passive and do nothing unless certain frequencies are present and then the part will perform as a 120 ohm resistor to block that noise. If all is working, leave it be. Nothing needs to be replaced.
        • burtDell
          • Feb 2025
          • 5
          Thanks mon2! I appreciate the insight and information.
            DELL Inspiron 5420 Notebook 5000 Specification for Upgrade or Repair
            This specification for the DELL Inspiron 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Inspiron 5420...
            09-07-2024, 06:38 AM
          • djpaesgana
            Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16
            by djpaesgana
            Hi i need help with a Dell latitude 14 5420 GDF40 LA-K491P Rev 2.0 (A01) 2020-11-16 , it charges on usb type C i checked the charger with a pd decoy and a electronic charge its ok when, i tested the usb c jack with a tail tester it reads ok (photo incluided), then with a usb charge tester it looks like its trying to negotiate the PD but ressets i openned the laptop and with a thermal camera i noticed 3 ICS getting hot the TPS65994 (UT3) the ISL95860HRTZ (PU601) and the IC SLGC55544CVTR (UI1) this one checking it on the micoscope looks damaged visually (picture incuided) and looking on the Boardview...
            05-14-2025, 08:12 PM
            DELL Latitude 5420 Notebook 5000 Specification for Upgrade or Repair
            This specification for the DELL Latitude 5420 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 5420 boardview and 5420 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 5420...
            09-07-2024, 06:31 AM
            09-07-2024, 03:40 AM
