Lenovo x1 carbon gen 9 - strange power problem.
  • pevata9811
    • Sep 2022
    • 8
    • bulgaria
    Hello, i have Lenovo x1 carbon gen 9. Laptop doesnt start on battery, but if you plug in the adapter and start the laptop, then unplug the adapter laptop will work fine on the battery. On adapter, laptop also charges. Do you have any ideas?
  • FriedFred
    • May 2024
    • 141
    The PD (power delivery) IC seems to me is damaged. The PD Controller is the managing IC between the mains power supply, the battery, the PD USB-Type C port, and the Mainboard.
    • pevata9811
      • Sep 2022
      • 8
      • bulgaria
      Thats the schematic. Which IC you think is suposed to do this ?
      Link to schematic --> https://www.badcaps.net/forum/troubl...d341-schematic
      • FriedFred
        • May 2024
        • 141
        Have you ever tried another battery? How is the sytem behave after fully charged the battery? Same behaviour?
        It can also be the initial battery circuit, like the fuse "F9", and diode "D19".
        Also check the MOSFET "Q34" for proper function.
        All current flows through this MOSFET. So, if it's damaged and the so-called "body-diode" is there only, then the battery can take current, but it can't deliver.
        • pevata9811
          • Sep 2022
          • 8
          • bulgaria
          i dont have another battery but laptops can work only on battery so i consider it godd. F9 , D19 , Q34 all good. Also all mosfets around battery cirquit.
          • FriedFred
            • May 2024
            • 141
            Is there a standby voltage, 3.3V and/or 5V, anywhere on the board, if external power supply is not connected and battery is connected?
            • FriedFred
              • May 2024
              • 141
              The broken component can be a double-diode in SOT23. One side is connected to the power connector, the other diode is connected to the battery. Both lines feed the standby-voltages which the EC-chip needs to monitor the ON/OFF-Switch and start.
