A2251 L8100 Diode Drop .009V Resistance 2.6Ohm
  • abajor
    • 175
    Trouble shooting an A2251, it is giving me the behavior that all three USB jacks except the DFU port are reading 5.18V .24A, the DFU port draws no current.
    Tried swapping that CD3217 from a donor, that changed to DFU port same behavior the adjacent USB port is now boot cycling, other side un effected.
    Hindsight probably should have checked the diode drops first.
    I removed L8100 to confirm that the PP1v1_S3 rail was "shorted" It reads about 2.4ohm and .009V on diode drop. The HighSide Low Side FETS before L8100 appear to be fine. Proper diode drop with reverse voltage.
    Odd when I inject 1V into the rail it draws about 0.09A I'm not seeing anything heating up on the ram chips at all.
    Has anybody seen this?
  • abajor
    A2251 820-0194 CD3217B12 (U3100_W) donors/replacements
    by abajor
    I have an A2251 820-01949 which had a failed TPS62180.
    I was fortunate enough to find the video on "Exploding USB-C" https://youtu.be/CAGnMR1aVuE?si=O1oYvAyNMeAr4dv4 what was shared here on the topic.
    I was wondering if there are any cross compatible models that have been discovered?
    We have an apple ID locked A2179 Mac AIR it's CD3217B2 has different lithography and looks slightly gray but I'm assuming it's the same chip in principal, but I am also aware that for some inexplicable reason mac flashes these chips firmware depending on their location on the board....
    06-27-2024, 01:10 AM
  • battery.12v
    Asus G512LI VCCCore raise and drop
    by battery.12v
    Hello guys, Asus G512LI, came with 3.3V drop down immediately .... 5V was stable ... after search and work found that +3VSUS_MUX is the issue (caused by U4701A TUSB1146RNQR) , left off the ic .. 3.3V came up again stable ... after power on laptop turn on for 3 seconds and power off ... VCCcore raise 0.9V for 1.5 seconds and drop down all other voltages do same thing ... Ram voltage , Gpu voltages, concerning VCCGT 0V all the time
    05-03-2024, 03:43 AM
  • tfm
    Drop-in replacement for STR-W6052S?
    by tfm
    The ma​in board of this LG washing and drying machine was damaged due to overvoltage. It is rated for 127V and was powered on 380V.
    Inicial visual inspection revealed that only some components at the input of the SMPS were damaged:
    Ironically, both fuses are intact. Probably the X2 cap and the bridge are also damaged. The whole board is immersed in an epoxy resin. I am removing it so I get access to the components.
    The SMPS is built around an STR-W6052S, which is discontinued and I can't get a replacement....
    02-16-2024, 08:29 AM
  • zhmih
    a2251 eDP lines dead
    by zhmih
    Hey guys,
    I have this display connector water damaged.
    PP5V_G3S_ALSCAM_was corroded, not the other side where lcd backlight is.
    nevertheless, EDP_INT_AUX_N and _P both have .0l in diode mode (not shorted to ground)
    I fixed the alscam line, restored laptop via dfu. I get chime but no image on internal and external display using type-c - hdmi cable (not the original apple).
    I tried displays from a1708 and 1706 but the result is the same(I do not have another a2251 display on hands).
    Question is should I try to find...
    11-15-2023, 05:07 AM
  • Junior††
    a2251 820-01949-a boot looping after screen replacement
    by Junior††
    not sure how it happened but after replacing the screen on a2251 macbook it:
    fans turn on for a second or 2, turn off, apple logo shows, 5-10 seconds pass and then system cuts off then cycles
    thermal camera shows these are getting quite hot although i'm not sure what do to.
    i've tried internet restore, same thing, put the old screen back on, same thing. which i'm inclined to think i f'd this up somehow or another. or the part that was given is faulty and caused something to go wrong. but I want to believe it's someone not me, but i'm prepared to think i...
    07-15-2025, 09:17 PM
