Lenovo ideapad 3 15IL05 - ram issue
  • piernov
    replied
    As far as I know this model (and some others from Lenovo) have the solder joints weaken under the CPU due to the low-temperature solder (138C°) and the underfill material as well as chassis flexing. CPU has to be reballed with regular leaded solder (183°C) or even lead-free (220°C).
  • Nagyesz
    replied
    Update:
    If I use it with the screen placed on the ground instead of the bottom cover, it doesn't freeze.
    I'll keep this bios on))
    Interestingly it doesn't freeze when moving the ram but rather when moving the lid
    Could be solder cracks?
  • Nagyesz
    replied
    I did it, but unfortunately, the problem is the same, although not immediately, and looks more stable
    It mostly happens when the laptop is moved.
    Click image for larger version  Name:	462576964_636397252246762_2776691451558573836_n.jpg Views:	0 Size:	87.0 KB ID:	3546309
  • LEO037_2029_
    replied
    @Nagyesz
    hi, try this bios program and feedback
    **** when you reprogram obviously don't forget to put physical ram in the ram memory socket ***
  • Nagyesz
    replied
    Here it is:
    (also tried to solder, without luck.
  • LEO037_2029_
    replied
    Nagyesz attach BIOS backup .and serial number. this method is remove RAM ONABORD in the bios. and you try to put memory ram fisic in the socket. but first attach here BACKUP BIOS.
  • Nagyesz
    replied
    Thank you for your idea, I will try it soon.
    Do you think the heat gun will work, or would a small tipped soldering iron be better?
  • juntmeako
    replied
    i just recently fixed an hp laptop with artifacting issue, i just resolder each pin of the ram slot and the problem goes away. u may try tapping each pin with a solder iron with a little amount of solder on it, of course put some flux on pins amd solder... be careful not to put a lot of solder to prevent pins bridges... at first i thought the ram slot is not the issue as i also inspecred under mscope all pins are good. u may try also...
  • Nagyesz
    started a topic Lenovo ideapad 3 15IL05 - ram issue
    I've encountered an issue I've never experienced before..
    The Lenovo works perfectly, it has 4gb soldered ram and an additional slot. With just the 4gb the laptop passes all tests, everything is working. However no matter what frequency or capacity of ram I add to the extra slot the display starts artifacting completely randomly in both in the bios and in win and the only solution is to shut down.
    I've inspected the pins of the extra slot with a magnifying and didn't notice anything unusual. I've also tried multiple ram modules, but the issue is the same.
    Any ideas?
