Asus x430un rev 2.1 - Disable RAM
  • igor1991
    • Jun 2018
    • 30
    • ukraine
    Hello.. Help disable the RAM on the board. Maybe someone has a schematic for this board?
    Asus Asus S430UF (BOARD x430un rev 2.1)
    • 20781
    Schematic requests go here --> https://www.badcaps.net/forum/troubl...-requests-only
    • Paras Sharma
      ASUS VivoBook Flip TP412FAC disable on board ram
      by Paras Sharma
      anyone can disable on board ram through bios editing because the internal ram is damaged. so that i can use only removable ram and bypass bsod errors of bad ram
      06-05-2025, 03:30 AM
    • DynaxSC
      ASUS STRIX Z490-F GAMING - No POST, stubborn board
      by DynaxSC
      I have this very stubborn ASUS mobo on the bench, and I already face the wall with it. It just refuses to POST, although everything seems to be OK.
      The situation looks like this:
      After connecting the board to the power supply on Nuvoton (SLP_S3#, pin 64), the Low signal (50 ohm resistance) appears immediately. PWRNTN# signal goes through Nuvoton to the chipset (confirmed after removing the chipset). The following conditions are then met for the chipset to generate the SLP_S3# signal:
      1. RTC oscillates normally (32.768KHz).
      07-08-2022, 05:45 AM
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • ShadowAi12
      ASUS ROG STRIX B550-F GAMING — Board not powering on properly
      by ShadowAi12
      I recently bought an ASUS ROG STRIX B550-F GAMING motherboard that was listed as "dead, not powering on." However, it does show some signs of life. I've performed several basic measurements and would like to share the results.
      • The board enters a "ready to power on" state after plugging in the PSU.
      • Pressing the power button increases power draw.
      • Sometimes, touching the RSMRST_L pad with a multimeter probe causes the board to shut off and return to standby.
      Measurements:
      (taken after pressing the power button, while the board is attempting to start)
      • H_SKTOOC#
      06-11-2025, 01:05 PM
