HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
  • my dodge
    • Dec 2018
    • 18
    • Persia
    Hello
    I was looking for a schematic or board view but unfortunately I didn't find anything.
    By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
    Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
    Please guide me.
    Thank you.​
  • mon2
    • Dec 2019
    • 14240
    From zbook 15 G3 schematic
    Click image for larger version  Name:	zbook1.png Views:	0 Size:	657.8 KB ID:	3527010
    • my dodge
      • Dec 2018
      • 18
      • Persia
      Originally posted by my dodge
      Hello
      Please guide me.
      Thank you.
      I reached the BQ24780s
      ​ IC by following the path of the pq58 ( TPCA8057-H
      ) pins.
      • mon2
        • Dec 2019
        • 14240
        The above schematic is the same as for your board.
        Remove all power. Meter in resistance mode. Measure the resistance across the mosfet pins to check if they are leaking.
        source (1-2-3) & drain (5-6-7-8)
        source (1-2-3) & gate (4)
        gate (4) & drain (5-6-7-8)
        Each measurement must be hundreds of k ohms or higher. Otherwise the part may be leaking and needs to be replaced. If found, flux and remove the part and allow it to cool. Then measure in the same way while the part is on your work table. Suspecting that the 1st DCin mosfet is defective.
        Carefully, measure the following voltage to ground for the following pins of interest with the adapter:
        ACDET ; pin 6
        REGN ; pin 24
        VCC ; pin 28
        ACDRV ; pin 4
        • my dodge
          • Dec 2018
          • 18
          • Persia
          ACDET ; pin 6
          REGN ; pin 24
          VCC ; pin 28
          ACDRV ; pin 4
          I have already removed the MOSFET from the board and checked it with a multimeter
          In diode mode with gate excitation, the source and drain values are the same in both prop positions and are about 0, and again with reverse gate excitation and the MOSFET is turned off, this value becomes a diode, which is o.l on one side and about 0.5 on the other
          But in ohm mode, the MOSFET between the drain and source shows about 3.9 M ohm on both sides, which is halved when the gate is excited and the MOSFET is turned on, so to speak, and becomes about 1.5 Mohms.
          The MOSFET appears to be healthy.
          • mon2
            • Dec 2019
            • 14240
            Review PQ56 - the 2nd dcin mosfet.
            • my dodge
              • Dec 2018
              • 18
              • Persia
              ACDET ; pin 6
              REGN ; pin 24
              VCC ; pin 28
              ACDRV ; pin 4
              But on the board and of course without a MOSFET, in ohm mode, the value between the source and drain is the same on both sides, approximately 400 kilohms, and for the gate, only when the negative probe is connected to the gate, we have a value of about 5.6 megaohms with the drain and about 4.96 megaohms with the drain, and in the positive probe mode with the gate, o.l is shown.
              • my dodge
                • Dec 2018
                • 18
                • Persia
                Yes, definitely
                I will check the voltages and let you know
                • mon2
                  • Dec 2019
                  • 14240
                  Test the removed mosfet in resistance mode for:
                  source / gate
                  gate / drain
                  • my dodge
                    • Dec 2018
                    • 18
                    • Persia
                    source / gate
                    gate / drain
                    Surprisingly, in both modes, the probes only display O.L for both requested modes.
                    • mon2
                      • Dec 2019
                      • 14240
                      Is your meter an auto-ranging type or manual type for the resistance mode? If manual, select a higher scale till you have a measurement. In summary, we are confirming that each resistance check is hundreds of K ohms or more.
                      • my dodge
                        • Dec 2018
                        • 18
                        • Persia
                        It is Auto Range and the result of this last test was very surprising to me.
                        • mon2
                          • Dec 2019
                          • 14240
                          There is the possibility that the mosfet is defective and therefore reporting the same 'OL' resistance. Test against another known good mosfet to compare.
                          • Popitto86 repair
                            • Jan 2025
                            • Italy
                            Hi everyone , I have recently joined this forum because of this issue with my Zbook 15 G3.
                            Same problem : led on the power button blinking / flat battery and can't turn on the pc.
                            I saw on youtube a video about this same issue , and shorting a capacitor w a pair of tweezers solved the problem 4 me.
                            I wanted to share with you my experience hoping it is helpful 4u too
                            The capacitor I shorted is the white one under "PQ56" written on the motherboard ( see picture ) .
                            Now my zbook is charging fine.
                              HP ZBook ZBook 17 G4 Mobile Workstation Mobile workstation 17 Specification for Upgrade or Repair
                              This specification for the HP ZBook ZBook 17 G4 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 17 G4 Mobile Workstation boardview and ZBook 17 G4 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-06-2024, 05:35 AM
                              HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation 15 Specification for Upgrade or Repair
                              This specification for the HP ZBook ZBook 15u G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 15u G3 Mobile Workstation boardview and ZBook 15u G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              09-06-2024, 05:30 AM
                              HP ZBook ZBook 17 G3 Mobile Workstation Mobile workstation 17 Specification for Upgrade or Repair
                              This specification for the HP ZBook ZBook 17 G3 Mobile Workstation Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook 17 G3 Mobile Workstation boardview and ZBook 17 G3 Mobile Workstation schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                              HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                              This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                              09-07-2024, 05:20 AM
