Lenovo IdeaPad Flex 5 cb 13ITL6 not turning on.
  • Patrick501
    • Oct 2024
    • 39
    Hey, I'm currently working on a Chromebook.
    Not turning on, no LED, power button= no reaction, USB-c charging cable plugged in shows 5V 0,00A.
    While checking for shorts, I noticed 13 ohms to GND at a coil (5V rail).
    I removed two resistors and the coil to locate the possible short. It turns out that the output of U43 drops from 143K to 13 ohms as soon it gets voltage on VCC.
    VIN1 und VIN2: 12 V 3V3LDO: 3,3 V
    BST: 3,3 V
    EN and OUT 0 V
    none of them less than 80 ohms except GND of course
    That doesn't sound right to me. I hope someone has an explanation?
    thanks in advance
  • mon2
    • Dec 2019
    • 14660
    You cannot measure resistance or in diode mode with power to the board.
    • Patrick501
      • Oct 2024
      • 39
      although OUT is powerless? For me it looked like that there has to be be something wrong with this low resistance.
      but ok... I will not continue looking any further in this direction then and move on with the charging circuit.
      Thanks for your answer mon2
      • mon2
        • Dec 2019
        • 14660
        5v issues are often USB port related. Inspect the USB port(s) and their load switches.
        • Patrick501
          • Oct 2024
          • 39
          You can find 1,8V, 3,3V, 5V and 12V on the board no matter which of the two USB ports I use (1xUSB_C on Mainboard, 1x on DB). So the ports should be alright..
          I just checked the charging circuit which seems to be ok.(I also checked https://www.badcaps.net/forum/troubl...arging-circuit)
          CC1 and CC2 in Diode mode 0,5
          still no LED, and charger not switching to 20V
          This laptop is a nightmare, I would've repaired multiple Macbooks in the same time.
          So I would appreciate any hint you could give me.
          • mon2
            • Dec 2019
            • 14660
            I am of the opinion that this model is capable of operating with the PD (power delivery) contract of 12v to power this logic board. If the PD controller interface was defective, you would have been stuck @ 5v but you are @ 12v so there has been some negotiations that have succeeded.
            Or would you have some confirmation that this power rail voltage is incorrect?
            Measure the VBUS pin on the active USB-C port - what is the voltage to ground? Your first post notes 5v @ 0A but the last post is listing 12v on the main power path.
            • Patrick501
              • Oct 2024
              • 39
              oh my bad ...PPVAR_VBUS_IN is 5V.
              USB tester also shows 5V/0A
              • Patrick501
                • Oct 2024
                • 39
                I had some time today to check more voltages.
                Every rail listed in G3 and AG state has the correct voltage except EN_PP3300_A which is 0V and of course the PP3300_A as well.
                • Patrick501
                  • Oct 2024
                  • 39
                  EN_PP3300_A is supposed to be produced by the EC but it's not happening. Is there any possibility to check without changing it?
                  mon2 Do xou have any idea how to move on or what else I can check?
                  • Patrick501
                    • Oct 2024
                    • 39
                    The EC came today and I replaced it. Unfortunately still not powering up, no 20V.
                    5V@0A
                    I don't wanna give up on this one, so I would appreciate any help I could get.
                      Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook 5 Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Flex 5 14ALC05 boardview and IdeaPad Flex 5 14ALC05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 04:10 AM
                      Lenovo IdeaPad IdeaPad Flex 5 14ALC05 Notebook Specification for Upgrade or Repair
                      Lenovo IdeaPad Flex 5 Hybrid (2-in-1) Flex Specification for Upgrade or Repair
                      This specification for the Lenovo IdeaPad Flex 5 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Flex 5 boardview and Flex 5 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                      09-07-2024, 07:20 AM
                      09-07-2024, 06:38 AM
