Acer E5-575 not detecting USB Keyboard & Mouse
  • shamaltech
    • May 2023
    • 110
    • Sri Lanka
    I have an Acer E5-575 Laptop of my customer.
    The problem is it doesn't detect USB Mouse and Keyboards.
    But USB flash drives, External HDDS are working fine.
    When I connect a USB Mouse or Keyboard, windows popup the error "USB Not Recognized
    The last USB device you connected to this computer malfunctioned, and Windows does not recognize it."
    I tried with different OS , flash BIOS but same problem.
    Any help?​
  • mon2
    • 14660
    Remove all power. Meter in diode mode. Red meter probe to ground. Black meter probe to point to test.
    Measure each pin on the usb connector.
    Post the list of measurements.
    Keyboard and mouse are usb hid usb models of devices. Should be natively enumerated without drivers. Do they work in the bios? Check security settings in the bios.
    • shamaltech
      • May 2023
      • 110
      • Sri Lanka
      Here are the measurements I got from both Usb 3.0 side and Usb 2.0 side.
      No they not work in Bios.I check security settings they are ok and also tried with another working laptop Bios.
      • mon2
        • 14660
        The one with the 0.062 is shorted. Inspect for nearby ESD TVS diodes. If found, flux and remove that part and then test again.
        • shamaltech
          • May 2023
          • 110
          • Sri Lanka
          I just found out that when I connect Mouse & Keyboard through a USB Hub to this port(circled on the photo),they are working fine.
          But other ports doesn't detect them even through the USB Hub.
          Any lead?
          • mon2
            • 14660
            What are the details of the port # that is working? Reference the label from the schematics.
            • shamaltech
              • May 2023
              • 110
              • Sri Lanka
              What details you need from schematics?
              • mon2
                • 14660
                There will be label associated with each USB connector. Which USB connector is working? Will make it easier to trace back to the host controller. Often, each USB port is controlled by the PCH (CPU). Trying to determine if the other ports are defective at the chip level or at the physical level. So far, the pics show the connectors to be defective.
