Asus UX303U booted directly into bios because of undetected ssd, and now it won't turn on
  • ZioSabatinoFiniuccio
    • Nov 2024
    • Italy
    Hello to all,
    i have an asus ux303u that freezed mid-work, than from there it booted only into bios and failed to detect ssd. The +5VS_HDD and +3V_HDD were missing because +5VS and +3VS were missing too. I saw they're created from +5VSUS and +3WA_DSW (both OK) through gate enabling signals generated from +12VS (that was missing) . On the PQ8807 the +12VS is generated from +12VSUS (measured 14,20V), P_LS_12VS_EN_10 (measured 14V) and SUSB_EC# (0 volts). I thought that the problem was on the U3001 (an IT8995VG) that were not creating the SUSB_EC# signal, but before i could do other measurings the notebook died. Now if I press the power button it turns on and off instantly. All the previous voltages go down and quickly back up to normal. Charging light works, but i noticed that the usb pendrive inserted on the charger side (but not on the other side) flashes if the charger is inserted, even if the notebook does not turn on. Is it possible that the U3001 died completely? Or am I totally off the tracks? Thanks
  • Sanjit Keskar
    Laptop mouse & KB NOT available on power option restart but available only when laptop is cold booted using power button
    by Sanjit Keskar
    I have this inexplicable problem from yesterday
    Each time i start my laptop by pushing the physical power button in, the laptop keyboard and touchpad are available to me for use when the system has booted to the desktop (I can enter the bios by pressing on F10 too) irrespective of whether the laptop is powered by the AC adapter or the battery. This is normal behaviour
    BUT NOW FOR THE ABNORMAL PART
    However, when using the laptop normally, if i choose restart from the power options, the touchpad and mouse are non-functional when the system has booted to the...
    06-06-2024, 10:35 AM
  • sew333
    Restore on AC power - question. Power outage and pc not booted again. But in power co
    by sew333
    Hi my pc: 10850K stock 4800mhz
    2x16 GB DDR4 GSKILL 3000mhz XMP
    Seasonic Tx-850 Ultra Titanium
    Gigabyte Rtx 3090 Gaming ( 2x8pin,2 separate pcie cables )
    Asus Z490 Maximus
    1 TB SSD
    Hi . I have an question. 5 days ago i had momentary power outage for brief moment. When power back pc not booted itself. I just presset reset button to turn on pc.
    In bios i have option RESTORE ON AC POWER - ON.
    But when i cut power by pressing off BUTTON on power cord for second and then turning on pc booting itself...
    01-05-2022, 08:13 PM
  • ipmungam
    Nvidia GT320 undetected.
    by ipmungam
    So, I found a Nvidia GT320 1GB DDR3 card on the side of the road, and now I'm in this forum.
    Cleaned it up -- the heatsink was completely full of gunk so there is a chance it has overheated and the GPU is fried. Obviously it's worth very little, but I have a project with no onboard video so this little card would be useful.
    Have tried it in two different motherboards, same behaviour: fan spins but the card is undetected. No obviously burned out components or damage.
    Following dicky96's youtube videos -- many thanks -- I've checked the resistances and...
    11-13-2021, 01:48 PM
  • Rimeyrep
    Acer Nitro 5 AN515-55 - Undetected Battery + Crashing under heavier load
    by Rimeyrep
    Board: Compal LA-J891P rev.1.0B
    Battery not detected
    Working only with AC adapter plugged in
    What happened:
    Notebook crashed under load randomly. After several crashes throughout the week (after each crash it got worse and worse meaning crashes were happening more often) i found out it works just fine not plugged in AC charger only powered by battery so i was using it that way until battery was drained to 5%. When i plugged AC charger in battery wasn't charging so i restarted the machine...
    05-16-2023, 02:48 PM
  • flisha26
    RTX 2060 6gb Undetected
    by flisha26
    Hello i'm trying to find the problem in my rtx 2060 6gb she stop working and we did not find the problem i have maked some test .
    when gpu star no signal nothing undetected.
    only the fan in the (Right) work.
    Gpu temperature normal i will say 65 degree.
    Nothing burned on the carte graphique.
    she was working normal on a motherboard b250m bazooka , I noticed a low fps after i restart my computer then the motherboard stop working and showing EZ debug DRam and the gup stop working.
    https://youtu.be/yVddDDy98tM
    https://youtu.be/yg9oWcinRmE
    05-10-2021, 05:04 PM
