Lenovo ThinkBook Gen 2
  • shybear
    • Jan 2010
    • 96
    hi,
    This laptop doesn't power / charge battery next a bit of water entered from rear causing a relly little oxidation (around 10 x 15 mm) near PU5401.
    Mainboard p/n is 5B21F20745.
    There isn't any sign of overheating and discrete components near the oxidation (capacitors and resistances) are fine.
    I've carefully cleanded and removed oxide but as attached picture of oxide damaged area looks like a missed resistance.
    I was looking for a boardview or schematic of mainboard without any success, but when power supply is plugged in I can reach a 12V near battery and also a 5V.
    Fuses are good.
    Without any scheme I tried to put a working resistance of the same value of the near one (100K) with any success.
    I need a scheme or a boradview to try to repair.
    Ale
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Mention clearly the topside marking of IC and try to locate another schematic with same IC or its datasheet. That way you can get an idea about the value of resistor used by tracing pin number of ic to which the resistor is connected.
    • shybear
      • Jan 2010
      • 96
      As attached picture I think that this IC is TPS51396A 4.5-V to 24-V, 8-A Synchronous Step-Down Voltage Regulator with ULQ.
      Reistor is connected to pin12 this is "Enable pin of buck converter."
      EN pin is a digital input pin, decides turn on or off buck converter. Internal pull down current to disable converter if leave this pin open.
      I'll try to find a schematic with IC then.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        May help you
        • shybear
          • Jan 2010
          • 96
          hi,
          thnks for your effort! I'm looking at least of a boardview / scheme of this mainboard. If you looks 100k jpg there is an other resistor and its 100k. Anyway I think should I find Vin if laptop is off? Because I can find 12V n the 2 capacitors on the right side of resistors and also on other two other capcitors junst under pin 1 of ic. This happen if I attach power keeping disconneted battery. If I plug battery voltage rise to 14V.
            Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook Specification for Upgrade or Repair
            This specification for the Lenovo ThinkBook ThinkBook 14s Yoga ITL Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 14s Yoga ITL boardview and ThinkBook 14s Yoga ITL schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-07-2024, 04:10 AM
            Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook Specification for Upgrade or Repair
            This specification for the Lenovo ThinkBook 13s-IML Ci5 16/512 13.3IN W10P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ThinkBook 13s-IML Ci5 16/512 13.3IN W10P boardview and ThinkBook 13s-IML Ci5 16/512 13.3IN W10P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-06-2024, 02:24 PM
            Lenovo ThinkBook 14s Yoga Hybrid (2-in-1) Specification for Upgrade or Repair
            This specification for the Lenovo ThinkBook 14s Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 14s Yoga boardview and 14s Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-07-2024, 07:20 AM
