Asus S510U
    Asus S510U
    Hello, i´m working on a Asus that have a strange issue... arrived to my store with a damaged battery connector, client open it and damaged the connector, already solder but now the laptop works fine but only charge the battery in this particle case:
    Laptop off plug the charge battery start charging and i can turn on and still charging, if i remove the charge and put the charge again battery will not charge... i have to shutdown the laptop remove the charge and plug it again...
    Already check the mosfets and replaced the BQ24780S, the motherboard is a X510UN, AC detect and AC OK are the same values when is charging and when is not charging...
    I am a little confuse.... the only difference i notice is a little difference on BATDRV 11V when is not charging and 12V when is charging...
    Help will be appreciated.
