A1181 coreduo => core2duo upgrade cpu
  • loser18
    • Nov 2013
    • 274
    Re: A1181 coreduo => core2duo upgrade cpu
    CPU rails have got always low resistance....eg. 10-15ohms (If CPU present)
    • drdyzio
      • Apr 2014
      • 74
      so ive been probin around lol.
      they seem shorted but gotta take them out my soldering irons plug is being used by oven atm for cooking food not mobos lol.
      i also been looking at caps in diode mode and most of them beep quickly and are good, i assume its due to it getting charged.
      but some just keep on beeping i could tell you which ones do and which ones dont but they are just random all around.
      but this could also be due to bad bga again.
      when i eat and get my power socket back ill pull them coils out and probe again.
      • drdyzio
        • Apr 2014
        • 74
        Can you give me a bit more detail on this im a bit of a noob and dont understand completely the terminology. eg cpu rails ....
        you saying that the resistance between the +vcpu and ground will be low anyway wid the cpu in.
        im learning everyday with the rest of the noobs here.
        love the input thanks
        • loser18
          • Nov 2013
          • 274
          What I mean, is the coils near CPU will read low resistance (when CPU present)...
          Since you have bga soldered CPU, that's the same as it would be in socket obviously...
          I meant CPU rail as VCORE or VCCORE voltage...
          I would get the schematic first and start from there...
          BTW I'm also noob...
          • drdyzio
            • Apr 2014
            • 74
            been looking its hard to find.. nothing is marked on the board id be lost but ill try to find something
            • loser18
              • Nov 2013
              • 274
              You got apple part number near the sodimm slot(right one)
              There's also another number but can't read it properly...
              It's either K36, K36C or M42B board...(never worked on macbook,so not sure, hate that crap,lol)
              • loser18
                • Nov 2013
                • 274
                OK...
                According Apple part no. it should be this 1...
                You're saying that L7500 & L7501 are shorted?
                It's on CPU VCORE PWR rail, so I assume they're OK,but desolder & check which side/pin is shorted...
                • drdyzio
                  • Apr 2014
                  • 74
                  As far as checking caps in circuit in "diode mode beep thing" why would it keep on beeping apearing to be shorted? i mean some right next to the ones that beep forever just beep quickly and go off.
                  and the ones on the parts board with no cpu or nb installed beep quickly and stop.
                  any ideas
                  thanks
                  by the way the schematics, site, and so for GREAT thanks a lot.
                  • loser18
                    • Nov 2013
                    • 274
                    I hope you're testing them with no PSU connected...
                    • drdyzio
                      • Apr 2014
                      • 74
                      yeah no psu connected.. the beeps am i checking it right?
                      as far as those other caps that blew you reckon its because of the heat in the reflow?
                      why would they just start melting lol
                      • loser18
                        • Nov 2013
                        • 274
                        what caps???
                        could you tell me the schematics marking (all of them)...
                        • loser18
                          • Nov 2013
                          • 274
                          how did you do reball???do you have proper BGA machine...what's your bottom heater settings?
                          • drdyzio
                            • Apr 2014
                            • 74
                            the thing is i cannot identify them on the schematics, but they are the ones in the pictures marked red earlier in the thread
                            and the black one im holding with my thumb was one of the ones blew.
                            • loser18
                              • Nov 2013
                              • 274
                              jeeez....even the coil is melted...I think you've shorted cpu with some other rail & that caused all of the caps to blew...
                                • 30977
                                the cpu is on the right way around i hope!
                                • drdyzio
                                  • Apr 2014
                                  • 74
                                  i set the bottom heater at 170 - 180 and wait till it hits that on top tc
                                  but my tc for my bottom heater pid was pointing away from the heatin element and therefore not reacting as quickly.
                                  im gonna replace some more caps and see what happens then ill try a reflow and back on the old cpu if that dont work.
                                  • drdyzio
                                    • Apr 2014
                                    • 74
                                    what coil is melted? am i blind lol
                                    • drdyzio
                                      • Apr 2014
                                      • 74
                                      so i poped these coils next to cpu out and they test very low resistance 1.0. same as on my parts board. idk how to test these.
                                      i couldnt tell which side it was on or how to tell. i hope u can clarify a tad bit for me.
                                      thanks for the patience
                                      • drdyzio
                                        • Apr 2014
                                        • 74
                                        yeah lol
                                        cpu is right way round..
                                          Inductors WILL test as low resistance - they are a coil of wire around a magnetic core (although a power inductor may be different, the principle is similar, direct electrical connection at DC.)
                                            HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC E6300 Specification for Upgrade or Repair
                                            This specification for the HP Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC boardview and Compaq dc7700p Intel Core2 Duo Processor E6300 2x512M/80G DVD-ROM WXP Pro Small Form Factor PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
                                            09-12-2024, 03:36 PM
                                            HP Chromebook Elite Dragonfly Chromebook Specification for Upgrade or Repair
                                            This specification for the HP Chromebook Elite Dragonfly Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Elite Dragonfly boardview and Elite Dragonfly schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                            09-07-2024, 06:40 AM
                                            HP Chromebook x360 11 G3 EE Chromebook 11 Specification for Upgrade or Repair
                                            This specification for the HP Chromebook x360 11 G3 EE Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 11 G3 EE boardview and 11 G3 EE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
                                            09-06-2024, 04:40 PM
                                            HP Chromebook 11 G8 EE Chromebook 11 Specification for Upgrade or Repair
                                            This specification for the HP Chromebook 11 G8 EE Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 11 G8 EE boardview and 11 G8 EE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for HP...
