Help needed locating LED fuse on Samsung NP550P7C-S05UK
  • Telephonewire
    • Apr 2014
    • 15
    • England
    Hi all.
    I have a Samsung NP550P7C-S05UK with no backlight. I have tested it with an external display which was fine.
    Holding a light up to the screen I can see the display is working fine but there's just no backlight.
    I rather foolishly removed / refitted the monitor cable with the battery connected. I feel so annoyed with myself and feel very sick that I now find myself in this position!
    I suspect that it is a blown fuse on the motherboard but I can't locate it.
    If anybody would be kind enough to offer any advice it would be very much appreciated.
    Best regards,
    Jeff
  • Telephonewire
    • Apr 2014
    • 15
    • England
    Re: Help needed locating LED fuse on Samsung NP550P7C-S05UK
    Np550P7C
    NP550
    • khaahk
      • Dec 2013
      • 759
      • Estonia
      I think there is no schematics available for that board, post good macro pictures of LCD connector and the opposite side of the mainboard. Fuse is one possibility, embedded controller is another. If you know how to use a multimeter, then maybe it is possible to give some assistance.
      • Telephonewire
        • Apr 2014
        • 15
        • England
        Hi Khaahk,
        Thanks for your message.
        I have only recently registered with the site and didn't realise that notifications were turned off by default. I have now turned them on for subscribed threads!
        I have uploaded two pictures; one of the motherboard and another more detailed one of the LCD connector.
        I do know how to use a multimeter! :-)
        Best regards Jeff
        • Telephonewire
          • Apr 2014
          • 15
          • England
          There are two components in the bottom right hand corner of the circuit board where the connector is (with no markings on) that look very similar, not sure if they are fuses or resistors (or something else)?
          There is another component just above then, which is horizontal, with a few letters / numbers on - is this a fuse?
          There is also a component (lighter in colour) at the top of the connector - is this a capacitor?
          All help gratefully received!
          Jeff
          • Telephonewire
            • Apr 2014
            • 15
            • England
            • atsio
              • Oct 2013
              • 819
              • Greece
              Open the screen and post the model of your monitor
              • khaahk
                • Dec 2013
                • 759
                • Estonia
                Take a picture from the opposite side of the connector also. The upper (lighter) component is capacitor (probably on +19V rail), the two components down right - can be capacitors or inductors, it is hard to tell from the pictures.
                The panel should get adapter power (+19V) and +3.3V, these power lines are delivered with broader vias on the pcb, that is how you can identify them. These power lines are probably switched by mosfets which are controlled most probably by EC (embedded controller).
                If these voltages are present on the connector, then there are also control signals for the LCD panel itself, to turn the backlight on, and adjust the brightness. They can be found via finding the lcd panel specification and tracing the signals back to mainboard.
                • Telephonewire
                  • Apr 2014
                  • 15
                  • England
                  Thanks Khaahk,
                  This is a learning experience for me!
                  I will take a picture of the other side of the connector and the screen and post shortly.
                  Could the two components down right be fuses?
                  Jeff
                  • khaahk
                    • Dec 2013
                    • 759
                    • Estonia
                    They look more like capacitors than anything else.
                    • Telephonewire
                      • Apr 2014
                      • 15
                      • England
                      Hi Khaahk,
                      Here is the picture of the back of the board and two pictures of the screen...
                      Best regards.
                      Jeffrey
                      • atsio
                        • Oct 2013
                        • 819
                        • Greece
                        Check voltage on pins 35, 36, 38, 39, 40 of the LVDS connector.
                        • Telephonewire
                          • Apr 2014
                          • 15
                          • England
                          Does anybody know where I can get hold of a schematic for the LED control board?
                          The screen is a B173RW01 V4
                          The control board is as shown in the attached photo.
                          Regards,
                          Jeffrey
                          • khaahk
                            • Dec 2013
                            • 759
                            • Estonia
                            specification is all you get:
                            atsio asked for the measurements of important pins on the panel, can you measure them?
                            • dspok
                              • Jan 2014
                              • 553
                              • Nepal
                              check F101 in TCON board, may be it is blown. Sometime I face such problems.
                              • Telephonewire
                                • Apr 2014
                                • 15
                                • England
                                Many thanks for advice - I will check when I get home tonight!
                                • Telephonewire
                                  • Apr 2014
                                  • 15
                                  • England
                                  p.s. What does TCON stand for?
                                  • aarvi
                                    • Aug 2014
                                    • Indonesia
                                    hey,
                                    this is my first post here,i also did the same mistake...
                                    did you find a solution....???
                                    • angel-boy
                                      • 550
                                      • Romania
                                      remove the shorted cap from picture , and change that source
                                      and have light again
                                      • emken
                                        • Nov 2014
                                        • 6
                                        • turkey
                                        Do you have np550p7c bios guys?
                                          09-07-2024, 05:50 AM
                                        • jesterace
                                          Samsung UE46ES8000 Blown fuse but no other signs of short
                                          by jesterace
                                          Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                                          09-11-2024, 03:14 PM
                                          09-06-2024, 11:40 PM
                                          09-06-2024, 08:40 PM
