Lenovo Ideapad 3 15ALC6
  • memoslar
    • Apr 2015
    • 122
    • Greece
    Hi, i need help on disabling Onboard Ram that may cause black screen on start. I attach the schematic.
    board is NM-D521Click image for larger version  Name:	IMG20240828134326.jpg Views:	0 Size:	3.77 MB ID:	3338365
    FIXABLE
    100.00%
    2
    NON FIXABLE
    0%
    0
    • 21869
    Post a link to the schematic https://www.badcaps.net/forum/troubl...f-this-section
    • nivminkov
      • Dec 2020
      • 15
      • Israel
      I would try taking it out with hot air and then clean the pads. You may also try to connect the reset signal to GND bit I you need to find some kind of resistor on the board so you will something to solder to (and I'm not sure there is something like that, it might be connected straight to the cpu)
        • 21869
        Look for the resistor straps in the schematic first and see if it can be disabled or not. If there`s no option you could try disabling in the bios https://www.badcaps.net/forum/troubl...ls#post3172363
        Edit.: replacing the bad ram chip is the other option
        • piernov
          • Jan 2016
          • 4439
          • France
          That's not how disabling onboard RAM works.
          SMDFlea is right.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            RC263/264/265/266 should be stuffed and
            RC272/273/274/275 should'nt be stuffed.
            Thats it for onboard ram disable.
            • memoslar
              • Apr 2015
              • 122
              • Greece
              Thank you for your answer. I moved the resistors in these places but no image again. (RC265 was already stuffed.)
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                If the resistor are moved/placed correctly,then onboard ram is 100% disabled and only dimm slot is active. Try putting another ram stick,look for soldering on ram slot pins,flash clean me bios.
                If these steps dont solve it,perhaps you're looking at dead end.
                  Lenovo IdeaPad 3 15ALC6 Notebook 3 Specification for Upgrade or Repair
                  This specification for the Lenovo IdeaPad 3 15ALC6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3 15ALC6 boardview and 3 15ALC6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo...
                  09-07-2024, 05:20 AM
                  09-07-2024, 05:00 AM
