Hello guys. After googling for 3 days and being unable to resolve the audio issue for some time I was looking for the schematic and I found this wonderful website.
It all started from sound just disappearing at some point that I even forgot when. Why did I forget? Because even though speakers and 3.5mm give no reaction whatsoever it works properly with type-c earplugs so I kinda kept using it like that. Now that I was doing an overhaul with repasting, changing pads and battery it struck me, hell, why not look for the sound issue? So here I am, after trying every possible software solution (drivers, bios, etc.)
As for the board, there are no apparent burns, the speakers show 3-4ohms each, however when I was checking the 3.5mm jack with multimeter and schematic I noticed too many grounds (shorts). I am far from a laptop repairman but I got the basic skills to read the schematic and use a multimeter so don't throw your slippers at me if I write newbie questions
Okay, so while in diode mode the speaker lines were okay but the mic lines seem to be shorted (Sleeve/Ring2). I am unsure, is it really a dead realtek here? Because it even has bidirectional TVS diodes on each jack line so I would think it's not that easy to burn it. Then again, if it did burn, why does the sound work from type-c?
In windows it doesn't show any input/output audio devices and doesn't react to headphones plug. I would think there's 3 options to this:
1) bad 3.5mm port;
2) bidirectional TVS diodes on mic burned and now make the mic shorted;
3) realtek chip died.
Would be very grateful for some help with this just so I know if its worth to find the reason or just use earphones and forget it. While there is also an option to just resolder the speakers to a cheap BT receiver PCB and connect it to a 5vdc line inside.
I've added the parts of the schematic in question below. Thanks in advance.
1) bad 3.5mm port;
