Aspire VN7-572 - VN7-572G no Power need help
  • DWCS
    • May 2021
    • 49
    • Sri lanka
    Aspire VN7-572 - VN7-572G - VN7-572TG RAYLEIGH_SL MB 14306-1M
    ​this board no power with c-mose battery. i remove the c-mose batter board working. need help to fix it i upload board view file rtc1
  • mon2
    • Dec 2019
    • 14254
    Check the dual diode @ D2501.
    Remove all power / remove the battery. Meter in diode mode. Measure the diode with red meter probe on pin # 2 & black meter probe on pin # 3. Should conduct. Reverse the meter leads and it should block.
    Repeat with pin # 1 & # 3. This dual diode may be defective.
    • DWCS
      • May 2021
      • 49
      • Sri lanka
      2pin and 3pin -322 in diod mode
      1pin and 3pin same
      • mon2
        • Dec 2019
        • 14254
        Now reverse the leads for each and test again. Probably ok but confirm it.
        • DWCS
          • May 2021
          • 49
          • Sri lanka
          i change prob and check no reading
          • DWCS
            • May 2021
            • 49
            • Sri lanka
            and i chage that diod but same fault
            • mon2
              • Dec 2019
              • 14254
              Measure the voltage to ground on pin #2 of this dual diode.
              Then check again on pin # 3. Post each measurement.
              • DWCS
                • May 2021
                • 49
                • Sri lanka
                pin#2 - 3.16v
                pin#3 - 3.09v
                • mon2
                  • Dec 2019
                  • 14254
                  Locate mosfet Q2505.
                  What is the voltage to ground of the DRAIN pin (RTC_DET#) with the CMOS battery installed?
                  What is the voltage to ground of the DRAIN pin without the CMOS battery?
                  • DWCS
                    • May 2021
                    • 49
                    • Sri lanka
                    voltage (RTC_DET#) with the CMOS battery 0V
                    without the CMOS battery voltage (RTC_DET#) 0V
                    • mon2
                      • Dec 2019
                      • 14254
                      Is there a charged battery or external power adapter attached to the board during these tests?
                      • DWCS
                        • May 2021
                        • 49
                        • Sri lanka
                        YES ADPTER PLUG
                        Thank you for helping me you are so kind to help me fix this
                        • mon2
                          • Dec 2019
                          • 14254
                          Locate resistor network RN601. Carefully measure the voltage on either pin # 1 or # 2 and this should be ~3v3 (3D3V_S5).
                          • DWCS
                            • May 2021
                            • 49
                            • Sri lanka
                            COMES 3.3V PWR BTN PRESS TIME
                            • DWCS
                              • May 2021
                              • 49
                              • Sri lanka
                              C-MOSE Once cleared it always works
                              • DWCS
                                • May 2021
                                • 49
                                • Sri lanka
                                BIOS CLEAN ME AND REPROGRAM IT'S SAME FAULT
                                • DWCS
                                  • May 2021
                                  • 49
                                  • Sri lanka
                                  i change finaly R1615 , C1603 , C1603. IT'S WORKING NOW THANK YOU SIR YOUR HELP TO ME. you are so kind 👬🙏
                                  • mon2
                                    • Dec 2019
                                    • 14254
                                    The fault was in the crystal area? Was this area damaged or just not oscillating? Well done! Thanks for the updates.
                                      ACER Aspire Aspire X3910 Aspire E5700 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire X3910 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X3910 boardview and Aspire Aspire X3910 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                      09-12-2024, 03:36 PM
                                      ACER Aspire Aspire XC-330 Aspire XC A4-9120e Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire XC-330 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-330 boardview and Aspire Aspire XC-330 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:30 PM
                                      ACER Aspire Aspire XC-886 Aspire XC i5-9400 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire XC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire XC-886 boardview and Aspire Aspire XC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      ACER Aspire Aspire TC-886 Aspire TC i7-9700 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire TC-886 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire TC-886 boardview and Aspire Aspire TC-886 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                      09-12-2024, 03:28 PM
                                      ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                      This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
