HP Pavilion x360 convertible
  • quezon
    • Dec 2015
    • 70
    • Philippines
    Hello guys. I need help identifying ic/mosfet. Board code chewbacca_14_kbl_r_dis_4g. Thank you.
  • Bonzas
    • 472
    • Indonesia
    Maybe this
    • quezon
      • Dec 2015
      • 70
      • Philippines
      Originally posted by Bonzas
      Maybe this
      Thank you very much.
      • quezon
        • Dec 2015
        • 70
        • Philippines
        Maybe this
        Hello guys. need help again. This unit has no display after replacing shorted AOZ5547QI mosfet as you can see no voltage output in one of the three mosfet's. What could be the problem I am missing. Thank you in advance.Click image for larger version  Name:	HP X360 Convertible (Chewbacca) with values.jpg Views:	0 Size:	480.4 KB ID:	3308755
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Cpu got killed by 19V as AOZ5547 shorted.
          • Sephir0th
            • Oct 2020
            • 1283
            Also you did a horrible and likely insufficient soldering job. Maybe you clarify now why you have replaced this DrMOS, since the values are still somewhat inconclusive. +VCC_GT is not supposed to show voltage without load. And share resistance measurements of all power supplies around the CPU
            FairRepair on YouTube
            • quezon
              • Dec 2015
              • 70
              • Philippines
              Thank you very much for the advise.
              • quezon
                • Dec 2015
                • 70
                • Philippines
                Thank you for noticing that, maybe I should invest with a better soldering iron and a microscope..
