Lenovo ideapad S540 USB issue
This topic has been answered.
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    So, there's this Lenovo, the USB is on a separate board, as far as I could tell, I examined it and didn't find anything unusual.
    When I checked the board with the multimeter, I didn't find 5V present, instead, there are 3V, 1V, and 0.7V. I'll attach everything I managed to measure
    Unfortunately, I couldn't find any documentation, boardview, or anything about this board
    Sometimes, Windows displayed the message, "The power consumption has exceeded the power supply capabilities of the receiving hub."
    What else should I measure to figure out why the USB isn't working?
    gs341 ns-c581 rev 1
    Click image for larger version  Name:	USB1.png Views:	0 Size:	731.4 KB ID:	3297257 Click image for larger version  Name:	USB2.png Views:	0 Size:	954.4 KB ID:	3297258
    Click image for larger version  Name:	USB.png Views:	0 Size:	1.71 MB ID:	3297259
    aClick image for larger version  Name:	SEGG.jpg Views:	0 Size:	301.1 KB ID:	3297261 Click image for larger version  Name:	SEG.png Views:	0 Size:	2.08 MB ID:	3297263
  • Answer selected by Nagyesz at 06-26-2024, 08:16 AM.
    mon2
    • Dec 2019
    • 14662
    Somewhere on this or perhaps the main board should be a USB load switch. It is the USB load switch that alerts the host USB controller of an excessive current draw. Very likely that load switch is damaged - most are just crap by design. Once damaged, the VBUS rail is lost and so are the USB functions. You will have to use the DIODE mode of testing from point to point to trace back the VBUS pin of the USB connector till you can load the load switch. Share more details of the load switch once it is found. The load switches are quite common and easy to replace with other brands.
    • mon2
      • Dec 2019
      • 14662
      • Nagyesz
        • May 2024
        • 124
        • Hungary
        Thank you mon2! I found what you mentioned, I'm almost certain about it. This ic is blown up right?
        Click image for larger version  Name:	448886078_3182447251891608_8632412700523517623_n.jpg Views:	0 Size:	154.0 KB ID:	3297313Click image for larger version  Name:	448695934_488958843503614_1557599592656895257_n.jpg Views:	0 Size:	148.6 KB ID:	3297314
        Located on main board part UI1 SN1702001RTER_WQFN16_3X3
        Click image for larger version  Name:	image.png Views:	0 Size:	18.5 KB ID:	3297315
        I do have lenovo motherboards for parts, is it common to find the same one? Also do you have suggestion where to buy the same ic?
        • mon2
          • Dec 2019
          • 14662
          Very good. Indeed the guilty party. You should be able to source through Digikey or Mouser or a donor board.
          Part # TPS2546RTER
          https://www.ti.com/lit/ds/symlink/tp...google.ca%252F
          • Nagyesz
            • May 2024
            • 124
            • Hungary
            Thank you, I didn't find similar from my parts so I'm gonna order it.
            If it's 99F instead of 998, or if the last segment doesn't match, is that okay? Because I found one that says 2546 TI 99F S244 - Will that work?
            • mon2
              • Dec 2019
              • 14662
              The top line of '2546' is the most critical to define this part and we know it is from Texas Instruments (TI). The rest are just manufacturer's datecode / place of manufacturing, etc.
              • Nagyesz
                • May 2024
                • 124
                • Hungary
                Thank you, I didn't know that. Also, thank you for all your help. I have ordered the part, and once it arrives, I will replace the faulty part.
                • Nagyesz
                  • May 2024
                  • 124
                  • Hungary
                  Update: The IC has arrived, I soldered it on, and the USB is now working perfectly. Thank you Mon2!!
                    Lenovo IdeaPad S540 Notebook S Specification for Upgrade or Repair
                    This specification for the Lenovo IdeaPad S540 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S540 boardview and S540 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo IdeaPad S540...
                    09-06-2024, 03:21 PM
                    09-06-2024, 02:34 PM
