HP Probook 640 g8 break Fuse / Flashing BIOS with 5V instead auf 3,3 CH341A
  • martin86
    • Jul 2021
    • 18
    • Austria
    i had a HP 640 G8 with a DA0X8AMB8E0 Board. I would Flash the BIOS, but i used a CH341A Programmer with 5V instead auf 3,3. Then I thought the BIOS was now defective. I have already replaced it with a new one (flashed the same BIOS).
    With the new chip, the notebook has the same error. The charging port lights up once and then goes out again. The notebook does nothing more.
    I iced the board with a cooling spray to possibly find a chip that gets hot or has a short circuit. Unfortunately, I didn't find any. I suspect a fuse might have blown. Does anyone have any ideas or is there perhaps a schematic for the board?
    Thanks.
  • mon2
    • 14662
    Way are the details of your power adapter? It should be a HP brand with 65 watt rating or higher.
    Locate where the power enters the board. Then study and share pics of the 8 pin mosfets and charger ic. Often, the fault is in this area. You will require a multimeter to troubleshoot the board.
    • martin86
      • Jul 2021
      • 18
      • Austria
      Hello, thank you for the feedback. I have tested multiple power adapters, each with more than 65W. The behavior is the same when the laptop is operated with the USB-C charging port.
      A circuit diagram or anything similar is not available for the board? The MOSFET and charger IC should be near the charging port on the motherboard?
      Thanks.
      • mon2
        • 14662
        Yes. Take a few pics of the area and post them here as attachments. The mosfets are often black in color with 8 pins (4 per side). Usually there are 2 x DCin mosfets that will follow the power adapter connector. These mosfets are enabled using the pin # 4 of the component and are driven by a pin on the charger IC. The charger IC is usually a square chip with pins on each side. HP likes to use charger ICs from Texas Instruments and are marked with a 'BQ' label on the topside. We need to know these details along with the mosfets to move forward.
        A very good reading is the sticky above by piernov on charger circuits.
        • martin86
          • Jul 2021
          • 18
          • Austria
          here are same Picture auf die Mosfet and Charger IC.
          • mon2
            • 14662
            The pics are not very clear to read the top side markings. Search for a square ic with topside markings with ‘BQ’ in the part number. If found, share a pic of that area.
            • martin86
              • Jul 2021
              • 18
              • Austria
              i found this 4 chips.
              • martin86
                • Jul 2021
                • 18
                • Austria
                a Chip with BQ Marking is not in the near.
                • alexfts20
                  • Jun 2023
                  • 30
                  • Kyrgyzstan
                  martin86 It appears that all the components you're referring to are MOSFETs.
                  The first one (3P3R0), in particular, seems to be a P-channel MOSFET used in the DC input circuit. To verify its functionality, please follow these steps:
                  Without power supply/battery connected
                  Measure the voltage drop between the Drain and Source. Expect about 0.5V.
                  With power supply connected
                  Check the voltage at both the Drain and Source relative to GND. It should match the DC input voltage, usually +19V.
                  P.S. For detailed specifications, you can search online for the datasheet of this MOSFET.
                  • martin86
                    • Jul 2021
                    • 18
                    • Austria
                    alexfts20 Hi, i check the 3P3R0. This Chip looks like OK, When Power is connected Drain und Source are at +19V like the DC input Voltage.
                    • martin86
                      • Jul 2021
                      • 18
                      • Austria
                      i habe Check the other Mosfet. Here the Picture with Voltage.
                      • alexfts20
                        • Jun 2023
                        • 30
                        • Kyrgyzstan
                        It must be from the opposite side of the board. It looks like there is no schematic on this board, but you can find the charger datasheet on the TI website.
                        • martin86
                          • Jul 2021
                          • 18
                          • Austria
                          mon2 and alexfts20 I found only one Chip at the opposite of the board that contains​ BQ Marking. Here are the Picture of the Chip and the Board from the other site. On this side there a no Mosfets.
                          • mon2
                            • 14662
                            The first pic with the BQ24780S is the charger IC.
                            Search this part on the internet to locate a sample datasheet. The logic board will very likely follow the sample schematics.
                            • pengamat_hebat
                              Problem Flashing Macronix MX25L6445E BIOS Chip with CH341A and EZP2019+ on ASUS X455LD
                              by pengamat_hebat
                              I'm trying to flash the BIOS chip Macronix MX25L6445E from my ASUS X455LD laptop using both a CH341A and an EZP2019+ programmer, but I keep encountering issues.
                              Reading the chip works perfectly, and I can extract the BIOS dump without any problems.
                              However, erasing and writing fail every time, regardless of the software I use. (Neo, asprog, ch341, etc)
                              I also tried applying 3.3V to pin 3, but it still didn't work.
                              I attempted to unprotect the chip, but when I read it back, the registers remained unchanged.
                              03-25-2025, 04:13 AM
                            • Andreasbest
                              Flashing 25Q256JVEQ with CH341A ?
                              by Andreasbest
                              Hello.
                              I try to flash a 25Q256JVEQ with CH341A but i can't, the content is written successfully but on verify i get match error.
                              Anyone knows if it's possible to flash 25Q256JVEQ with CH341A or not?
                              Thank you in advance!
                              12-21-2024, 11:11 AM
                            • corrize
                              A funny fuse story – Lumix LX100 II
                              by corrize
                              Hello, I disassembled this dead camera, and found this WTF… Two fuses soldered one above the other !
                              I was pretty sure nobody touched it before, but that can't be from factory. There is flux, and capacitor is probably missing.
                              The other weird thing : the fuses are « G » fuse : (0.75A – 8V), seems very low. The original fuse should be « O » : (32V 2,5A).
                              There is « O » mark beside. All fuses have the same mark letter on main board. So, I can deduce it's a « O » fuse.
                              And this correspond to the issus I saw : when I plug the battery, I measure the voltage dropping...
                              10-19-2023, 09:58 AM
                            • md500
                              [Question] Ch341a and 5v to 3.3v with logic converter
                              by md500
                              zz0.8tpitu4y0i8zzI bought a ch341a (I'm waiting for it to arrive) and I noticed that the programmer has a bug that the data pins go to 5v when the VCC pin is at 3.3v (which is the voltage I'm looking for).
                              Instead of doing the 3.3v mod, I'm thinking of converting the 5v to 3.3v with an 8 channel TXS0108E through the ZIF socket but I don't know if that would work, because it has to circulate voltage and also information.
                              What I am looking for is something that will convert from 5v to 3.3v but without modifying the ch341a.
                              I can't buy the ch341a 1.6v that has...
                              05-24-2024, 06:51 PM
                            • jesterace
                              Samsung UE46ES8000 Blown fuse but no other signs of short
                              by jesterace
                              Hi I wonder if anyone might be able to steer me in the right direction. I have this Samsung UE46ES8000 TV and it went bang during use. The main fuse on the PSU board is open. I've checked every diode/mosfet/transistor I can see and nothing appears to be short to cause the fuse to go. The DC output of the bridge rectifier is not short either. I've seen online that some of these models are known for having their PFC mosfet or other mosfets shorting and blowing the fuse but i'm not seeing that here. If anyone aware of these models having any issues to cause this? I'm reluctant to just replace the...
                              09-11-2024, 03:14 PM
