Acer Nitro 5 (AN515-54) No charge No power
  • earwig_nick
    • May 2024
    • 7
    • United States of America
    Hello all,
    I'm working on an Acer Nitro 5 (AN515-54) with motherboard EH5VF LA-501P with a short on the power rail.
    I'm just learning board level diagnostic, but here is what I've found so far.
    I injected 1.5v to one of the positive leads on the DC jack connector (PJP101) and read about 1.4a to ground.
    I felt around for heat and found the MOSFET at PQB12 is rippin hot!
    when i pulled the MOSFET from the board the short went away. In my mind it was a faulty MOSFET.
    Ordered a replacement and got it installed only to find it gets very hot again and the short returns.
    Looking around I don't see any obviously damaged caps or components. maybe the fault is in PUB1?
    Like I said I'm very new to this but I feel like I've got to be close.
    Any thoughts or suggestions would be awesome!
    -Earwig
  • mon2
    • 14669
    With no power to the board, meter in resistance mode, measure the resistance to ground of the ACN / ACP pins on pub1. You are checking if there is a short on the main power rail that follows the 2 * dcin mosfets of which you have replaced one so far.
    Post the measurements in ohms.
    • earwig_nick
      • May 2024
      • 7
      Pardon my ignorance:
      Which pins are you referring to?
      I don't see ACP on this diagram.
      • earwig_nick
        • May 2024
        • 7
        On pins 31 and 32 (CSIN and CSIP) I'm showing 3.2ohms and 2.2ohms respectively.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Your main rail of 19V is shorted to GND. De solder the CLR just after dc-in mosfets and inject 1V/5A on the shorted side of CLR pad and see what gets hot.
          • earwig_nick
            • May 2024
            • 7
            Would you point out the CLR? I’m not exactly sure what you’re referring to.
            • rogfanther
              • Jul 2006
              • 458
              • Brazil
              It´s a small value resistor on that path. Also, please link to board schematics for your board, if they are in the schematics sub-forum.
              • Luís Amaral
                • Nov 2013
                • 78
                • Portugal
                This motherboard is a CPU Killer
                • earwig_nick
                  • May 2024
                  • 7
                  Thanks! here's where I got the schematic I'm using:
                  https://www.badcaps.net/forum/troubl...eh5vf-la-h501p
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    PRB4 is CLR. measure resistance to GND on any pads of PRB4. If its in ohms,19V rail is shorted. desolder it and recheck resistance to GND on both pads and then proceed to inject 1V/5A on the shorted pad of this CLR.
                    Hope you can understand my suggestion clearly.
                    • earwig_nick
                      • May 2024
                      • 7
                      Got it. I will do that on Monday and report back when I can.
