Lenovo Ideapad 320-15ikb: Comes on and goes off
This topic has been answered.
  • Nagyesz
    • May 2024
    • 124
    • Hungary
    I've been thinking about this too, that might be the issue. I'll check it soon. Could you possibly tell me what mode to use the meter and what exactly I should measure?
    • Nagyesz
      • May 2024
      • 124
      • Hungary
      It's been wiped out with alcohol again, the situation has changed a bit, but unfortunately it still behaves the same way at startup.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        My gut feeling tells me that your problem lies near UC4/QC2 area. Check each and evry track with your multimeter.
        Btw, what is the change after cleaning this area?
        • Nagyesz
          • May 2024
          • 124
          • Hungary
          Thank you very much for the response. But as I mentioned, I'm not that good with the meter, so if you could tell me which mode and how to start, I'd appreciate it.
          After the cleaning it still behaves the same way. Goes on for few seconds then off and red blink
          • Nagyesz
            • May 2024
            • 124
            • Hungary
            @UC4 in Diode Mode
            1-2 6-7 pin is beeping with eachother (+1.0VALW)
            pin 4 beeping with @ UC2 pin 5 (+5VALW)
            pin 14 and 13 beeping with eachother (+VCCIO)
            pin 14, pin 13 beeping with @C1102 and @cc1250 1 pin
            pin 12 beeping with @CC1293 (N25889877)
            pin 12 beeping with N25889877 (trace?)
            pin 11 gnd is ok
            pin 10 beeping with @CC1292 pin 1 (N25889881)
            pin 9-8 beeping with eachother, beeping with @CC86 pin1 and @RC1604 pin 1 and @RC105 pin 1
            @QC2 in Diode Mode
            pin 6 beeping with @RPC20 pin2 and PCH_SMB_CLK
            pin 5-2 beeping with eachother and @QC10 pin 2-5 and @U1 pin 1
            pin 3 beeping with @RPC20 pin1 and beeping with PCH_SMB_DATA
            Click image for larger version  Name:	Capture.jpg Views:	0 Size:	15.2 KB ID:	3271501 @QC2 pin 2 is beeping with this
            @RPC25 pin 2 and @QC10 pin 3 (PCH_SML1_DAT) doesn't peep with TB-TP486 (look attached) I tried everything and not a single beep
            Click image for larger version  Name:	eee.png Views:	0 Size:	2.04 MB ID:	3271502
            Edit: @RPC25 has 3.3V and TB-TP486 has 0.5V-0.6V somehow
            • mon2
              • Dec 2019
              • 14294
              If you are testing in DIODE mode -> be sure there is no power to the board.
              Red meter probe (yes RED) to ground and BLACK meter probe to the point to test. Then record the measurement and post your values.
              • Nagyesz
                • May 2024
                • 124
                • Hungary
                #27
                I did it exactly the same way, the recorded values ​​are up. I measured the Volt by plugging it into the charger.
                • mon2
                  • Dec 2019
                  • 14294
                  Wait..if you are checking the voltage to ground of any component, the meter must be in DC Volts mode (not DIODE mode). No beeping will occur in DC Volts mode. In this mode, the BLACK meter lead will be to ground and the RED meter lead to the part to test. You are measuring the voltage potential to ground.
                  Only if you are wanting to test in DIODE mode, then use the DIODE mode scale with red meter probe to ground and black meter probe on the component to test.
                  Each test method has its benefits but be sure that in DIODE mode or RESISTANCE mode, there is no power to the logic board. This is important.
                  • Nagyesz
                    • May 2024
                    • 124
                    • Hungary
                    #29
                    Sorry, I worded it poorly. I measured in diode mode just as you said, and I also measured the voltage correctly I think.
                    But I think there is an error, and that is with TB-TP486
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      The motherboard is on your table and continuity check only you can do. We've guided you to the rpobable fault area. You need to look carefully to find something.
                      Read the diagram a bit and you can easily figure out that pin1-2/6-7/8-9/13-14 are in continuity-so why waste your time measuring that way. Simply meaningless.
                      What is the voltage on pin1-2/6-7/8-9/13-14 of UC4 after pressing power button?
                      • Nagyesz
                        • May 2024
                        • 124
                        • Hungary
                        #31
                        @QC2
                        On cable:
                        pin 3 3.36V
                        pin 2 0V
                        pin 1 0V
                        pin 4 0V
                        pin 5 0V
                        pin 6 3.36V
                        After pressing power button:
                        pin 3 3.36V for few secs then 0V then 3.36V
                        pin 2 stays 0V
                        pin 1 stays 0V
                        pin 4 stays 0V
                        pin 5 stay 0V
                        pin 6 for few secs then 0V then 3.36V
                        @UC4:
                        on cable
                        only pin4 has 5.1V
                        pin4 has 5.1V for few secs then 0V and then 5.1V
                        @Pl202 and Pl201
                        On cable 8.4V both
                        After pressing powerbutton
                        8.4V drop to 0.21V and (!) stays there I need to replug the power to get them back to 8.4V
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #32
                          Going by your reading at QC2,3VS is missing.
                          Measure voltage on pin1-2/6-7/8-9/13-14 of U13(after pressing power button).
                          • Nagyesz
                            • May 2024
                            • 124
                            • Hungary
                            #33
                            As soon as I have a minute, I will measure it. Thank you!
                            • Nagyesz
                              • May 2024
                              • 124
                              • Hungary
                              #34
                              @U13
                              pin 1 5.1V then 0
                              pin 2 5.1V then 0
                              pin 3 5.1V then 0
                              pin 4 5.1v then 0
                              pin 5 5.1V then 0
                              pin 6 5.1V then 0
                              pin 7 5.1V then 0
                              pin 8 5V then 0
                              pin 9 5V then 0
                              pin 10 10.16V then 0
                              pin 11 0v
                              pin 12 5.1 V then 0
                              pin 13 5.1V then 0
                              14 5.1v then 0v
                              I might have done something wrong because UL1 is getting very hot, and you can feel the processor heating, when it's turned on
                              • Nagyesz
                                • May 2024
                                • 124
                                • Hungary
                                #35
                                Yea I actually managed to short something
                                Pl401 went from 21.3kohm to 0.04ohm 😶
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  #36
                                  PL401 is +3VALW line and its dead short to GND now.This is bad news.
                                  Very likely PCH part of SOC is shorted(smaller die) as well as SIO.
                                  It seems your multimeter probes are not needle sharp and you accidentally touched 2 different rails while measuring.
                                    Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 3 17ITL6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 17ITL6 boardview and IdeaPad 3 17ITL6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 05:20 AM
                                    Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 3 15IGL05 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 3 15IGL05 boardview and IdeaPad 3 15IGL05 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15IHU6 Ultrabook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15IHU6 boardview and IdeaPad Gaming 3 15IHU6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                    Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook 1 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad 1 14IJL7 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad 1 14IJL7 boardview and IdeaPad 1 14IJL7 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                    09-07-2024, 05:00 AM
                                    Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook 3 Specification for Upgrade or Repair
                                    This specification for the Lenovo IdeaPad IdeaPad Gaming 3 15ACH6 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the IdeaPad Gaming 3 15ACH6 boardview and IdeaPad Gaming 3 15ACH6 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
