HP Gaming 16-a0006nl - no charge / no power
  • ShocK-306HDi
    • May 2014
    • 16
    • Italy
    Hi friend, I've this notebook HP Gaming 16-a0006nl with QUANTA DAG3JBMB8D0 that won't power on.
    I start checking first mosfet and they seems to be ok.
    On power button I get 3 that go to 0 on pressing, and come to 3v on release.
    After I check charge ic that is BQ738H
    I write here measure with battery and ac
    19
    19
    19
    25
    3
    1.9
    0
    3.1
    3.1
    1
    11
    11
    11
    gnd
    0
    6
    10
    11
    11
    19
    I've 0 on pin 7 IOUT and on pin 15 LODRV.
    What can I check.
    Thanks for your help
  • mon2
    • 14995
    Can you reformat your measurement table and post it again? Which pins were measured?
    • ShocK-306HDi
      • May 2014
      • 16
      • Italy
      Yes yes of course, sorry !
      1 ACN: 19
      2 ACP: 19
      3 CMSRC: 19
      4 ACDRV: 25
      5 ACPRES: 3
      6 ACDET:1.9
      7 IOUT: 0
      8 SDA: 3.1
      9 SCL: 3.1
      10 ILIM: 1
      11 BATDRV: 11
      12 SRN: 11
      13 SRP: 11
      14 GND: 0 gnd
      15 LODRV: 0
      16 REGN: 6
      17 BTST: 10
      18 HIDRV: 11
      19 PHASE: 11
      20 VCC: 19
      • mon2
        • 14995
        Are you using the proper rated power adapter?
        The following is too low:
        6 ACDET:1.9
        Thus should be 2v4 or higher.
        • ShocK-306HDi
          • May 2014
          • 16
          • Italy
          I'm using Regulated Power Supply set on 19.5 v
          • mon2
            • 14995
            ACDET must be 2v4 or higher to enable. This value is from a resistor based voltage divider.
            Would you have access to the official power adapter?
            • ShocK-306HDi
              • May 2014
              • 16
              • Italy
              Yes, I've checked with official HP AC Adapter, but not changing....same 1.9v , I also measure 2 resistor connected on ACDET line and they are OK, I also have a capacitor, I would to try remove it ?
              • mon2
                • 14995
                Can you link the schematic for this board? (only if it is posted in the schematic forum)
                Also, can you share the 2 resistor values that are on the ACDET line? Need the high side and low side resistor values. You can measure the resistance to ground on ACDET and the measurement should be close to the low side of the resistor value. If not, then the capacitor is affecting the resistance. For now, leave the capacitor in circuit but we may have to review these resistors.
                Do you have a stable 19v5 as the input to the logic board? This voltage does not drop during use?
                • mon2
                  • 14995
                  See attached. With no power to the board, measure the resistance with your meter across PR1031.
                  What is the resistance?
                  Repeat with testing across PR1032.
                  If you are comfortable, use low air pressure + flux and carefully move the resistors so they can be measured. Do not rush it else the parts can go flying off the board. Suspecting that you have a fault here and the ACDET voltage is below the required threshold of 2v4.
                  The measurement without the parts being in-circuit is always more accurate than being in-circuit.
                  • ShocK-306HDi
                    • May 2014
                    • 16
                    • Italy
                    Okok
                    Measuring resistances isulated from circuit I've PR1032 with 49 kohm, on PR1031 I've 0,430 mhom
                    • ShocK-306HDi
                      • May 2014
                      • 16
                      • Italy
                      Measuring PR1031 without power I get 247 kohm
                      PR1032 49 kohm as in schematic
                      Abnormal is PR1031
                      • mon2
                        • 14995
                        Voltage @ ACDET is too low so there is still some other factor here. If PR1031 is lower than the schematic, the voltage of ACDET will be higher. At the very least, we need ACDET to be 2v4 or a bit higher.
                        Do you have other resistors available to you?
                        Use this online resistor based voltage divider calculator to configure this network so that ACDET is higher than 2v4. Apply the resistor values available to you for PR1031.
                        Summary : Decrease the high side resistor value till the 2v4 threshold is met or is a bit higher. Only then will this charger IC accept the external power adapter supply to be suitable to power this board and charge the battery.
                        Voltage Divider Conversion Calculator | DigiKey
                        • ShocK-306HDi
                          • May 2014
                          • 16
                          • Italy
                          Yes, I can take other resistor to from other bad board....but I've never done this
                          If I found an exact 430k resistor as in schematic for PR1031, that would be much better...
                          • mon2
                            • 14995
                            Best to practice, practice on a donor board. According to the calculator, these values and this adapter voltage will not be high enough @ ACDET pin. However, you can test the parts you have.
                            • ShocK-306HDi
                              • May 2014
                              • 16
                              • Italy
                              If I inject 2.4 volts on ACDET with my regulated dc power supply, it is not the same thing ?
                              • mon2
                                • 14995
                                That should be ok as well. The ACDET is just that, a detection that the power adapter is present and the resistors dial down the high voltage to a safe value.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  What is the voltage on AD_ID? While using dc supply are you using PS_ID converter for HP160W.The usuall PS_ID converter for HP's is 90W-so using dc supply the mb wont power on at all. Moreover,with gaming m/b's you need to set your dc supply at 21V and not 19.5V. Better to use HP original adapter and measure AD_ID voltage. Does the dc jack light glows?
                                  • ShocK-306HDi
                                    • May 2014
                                    • 16
                                    • Italy
                                    I tried, but nothing changed, I inject 2.4 volt with my power supply without changes, battery not charge, if I measure with tester on BATT+
                                    On AD_ID nothing... 0 volt.
                                    I've tried set power supply to 21v but nothing change
                                    On DC Jack it doesn't turn on the light
                                    I see the light, only when I unplug power supply cable from dc jack, it blink just one time and stop.
                                    • mon2
                                      • 14995
                                      Hp Laptop Adapter ID pin Resister Value #lciit Laptop Repair Tutorial (youtube.com)
                                      • ShocK-306HDi
                                        • May 2014
                                        • 16
                                        • Italy
                                        I want to thank the users mon2​ e mcplslg123 for the great help in solving the problem with this laptop, with a 150w HP power supply the computer started working again.
                                        On the AD_ID pin I get 12v, the computer charges, turns on and everything works.
                                        Thanks friends
                                          ASUS TUF Gaming FX506HF-HN028-GAMING Notebook F15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX506HF-HN028-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX506HF-HN028-GAMING boardview and FX506HF-HN028-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-07-2024, 06:38 AM
                                          ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook A15 Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FA506IU-HN153T-Gaming Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FA506IU-HN153T-Gaming boardview and FA506IU-HN153T-Gaming schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 11:20 PM
                                          ASUS TUF Gaming FX505GM-AL323-GAMING Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX505GM-AL323-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505GM-AL323-GAMING boardview and FX505GM-AL323-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-06-2024, 09:01 AM
                                          ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook Specification for Upgrade or Repair
                                          This specification for the ASUS TUF Gaming FX504GD-EN1324-GAMING Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX504GD-EN1324-GAMING boardview and FX504GD-EN1324-GAMING schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook GP Specification for Upgrade or Repair
                                          This specification for the MSI Gaming GP73 8RE-062UK Leopard + Gaming Voucher Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GP73 8RE-062UK Leopard + Gaming Voucher boardview and GP73 8RE-062UK Leopard + Gaming Voucher schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-06-2024, 08:41 AM
