HP Elitebook 2540p - WP884AW#ABU - won't start!
  • smaniak
    • Nov 2017
    • 80
    • Bulgaria
    The laptop won't start. When plug power supply, on 19V in gives me 0,14A, without turning on the laptop.
    I check it with thermal camera, and there is one resistor that is very hot, I change the resistor with new on but the result is the same.
    In the attachment there is schematic of the resistor area, and schematic of the laptop.
    I can't understand, why this resistor is getting so hot.
  • mon2
    • Dec 2019
    • 14120
    Remove all power. Meter in resistance mode. Measure the resistance to ground on the side at ~4v4. Post the measurement.
    • smaniak
      • Nov 2017
      • 80
      • Bulgaria
      On the 4.4V side, resistance to ground is like 30,68MOhms
      • mon2
        • Dec 2019
        • 14120
        Flux and lift up one leg of diode PD22.
        Power up again and check if this resistor is still getting hot.
        What is the voltage to ground now on each side of this resistor?
        • smaniak
          • Nov 2017
          • 80
          • Bulgaria
          The resistor is still getting hot, and the voltages are the same.
          • smaniak
            • Nov 2017
            • 80
            • Bulgaria
            I lifted up PD2 and PD8 and still the problem was there. Then I decided to remove TPS51125RGER and now the mesurments aroudn resistors are OK.
            • mon2
              • Dec 2019
              • 14120
              Then the earlier resistance check to ground was in error. Measure the resistance to ground again after this 100 ohm resistor and post a pic of your meter face with the measurement. This resistor will only be hot if there is a heavy load on the downstream side.
              • smaniak
                • Nov 2017
                • 80
                • Bulgaria
                This is after 100ohm resistor to ground now, without TPS51125RGER.
                • smaniak
                  • Nov 2017
                  • 80
                  • Bulgaria
                  I found TPS51123 on one of my old motherboards, and I put it instead of old one TPS51125 /that was on the board originally/. The result is the same, this resistor is still very hot.
                  • smaniak
                    • Nov 2017
                    • 80
                    • Bulgaria
                    This is from the thermal camera.
                    The hotest one is the resistor.
                    The other one near to resistor is PU303 - APL5317.
                    And the far right is TPS51123​
                    • smaniak
                      • Nov 2017
                      • 80
                      • Bulgaria
                      This is motherboard shcematic.
                      https://www.badcaps.net/forum/troubl...-2540p-rev-1-0
                      • mon2
                        • Dec 2019
                        • 14120
                        PD22 is a diode so has a polarity. In the post with the meter, unable to confirm that this diode is properly mounted. Be sure that the band on the diode is in the proper direction.
                        The backside of the arrowhead = ANODE = "+' or input to the diode. Respectively, the front side of the arrowhead = CATHODE = "-". The current will flow in the direction of the arrowhead and must match the schematic.
                        Confirm this important detail.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          TPS51123 & 51125 are different and not interchangeable.
                          • smaniak
                            • Nov 2017
                            • 80
                            • Bulgaria
                            Yes You are right!!! I returned TPS51123!
                            The other thing that I see was that KBC1098 was solder incorectly. So I replaced It with new one.
                            And now when I plug the charger, the carger switch off for short.
                            With another scan with thermal camera I faund that PQ205-IRFH7914 is glowing.
                            I replace PQ205 and now the laptop is starting. BUT the fan is spining at full speed and there is no picture.
                            When I plug tester on mini pci there is nothing, 00 and no other codes.
                            My qestion is, is KBC1098 programmabal or not?​
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              KBC1098-NOT programmable.
                              • MidnightRoller
                                Can a resistor lose resistance after hot air?
                                by MidnightRoller
                                I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                02-02-2022, 11:46 PM
                                HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:50 AM
                                HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                                This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                                09-07-2024, 05:20 AM
