ASUS RUF GAMMING
  • Repair Electronics
    • Apr 2024
    • 12
    • United Kingdom
    ASUS RUF GAMMING
    Anyone know moatherboard ruf the blacklight fuse ? Where they are ? Is an AMD Ryzer 5 i spend couple of hours to fiind it and still not fiind nothing....the problem is once i connect the afaptor i have image but not blacklight..when i remove the adaptor and stay on battery i not have at all image...and i thing so is the fuse problem
    • 20279
    Post more info,such as the full laptop model number ( RUF GAMMING​ ?) and the motherboard model number. https://www.badcaps.net/forum/troubl...r-s-guidelines
      • Apr 2024
      • 12
      • United Kingdom
      The Laptop show image but no have blacklight if is plug in the charger, if is stay on battery dosnt show nothing on screen ...is so strange him symtoms The LVDS was replaced the screen was replaced because was beoken aswell ,
        • Apr 2024
        • 12
        • United Kingdom
        I try to resset the bios , i try to discconeected all the same...if i use HDMI i have clear nice image laptop works perfect...the problem is some power not comming at all...to give blacklight when the charger is plug in and turn the screen on when is on battery
          • Apr 2024
          • 12
          • United Kingdom
          Checking the geound with Capacitors my multimetter beeping...almost half of the Moatherboard
          • reformatt
            • Feb 2020
            • 1398
            Schematic/Boardview for FX505DY
            https://www.badcaps.net/filedata/fetch?id=2130115
            https://www.badcaps.net/filedata/fetch?id=2130116
            Check
            L4501 for continuity, 19V at pin 40 CON4501
            +LCD_VCC
            LCD_BACK_PWM
            LCD_BKEN_CON
              • Apr 2024
              • 12
              • United Kingdom
              Thanks i will check and let you know cheers thank you
                • Apr 2024
                • 12
                • United Kingdom
                I not have 19v on screen what can be issue ??
                • mon2
                  • Dec 2019
                  • 13829
                  Search for a white body fuse nearby this display connector. Post clear pics of this area. Top and bottom side views.
                    • Apr 2024
                    • 12
                    • United Kingdom
                      • Apr 2024
                      • 12
                      • United Kingdom
                      Thanks guys for helping me kind regards
                      • myth77
                        • Feb 2017
                        • 380
                        • Croatia
                        Here it is, you should have 19 v on both side, and that fuse has to be shorted (between pins 0 ohms)
                        Click image for larger version  Name:	Snimka-zaslona-2024-04-29-134530.png Views:	0 Size:	398.5 KB ID:	3262187
                          • Apr 2024
                          • 12
                          • United Kingdom
                          I have 17v after that but before that i have 19v.
                            • Apr 2024
                            • 12
                            • United Kingdom
                            Id this one the fuse ? Looks so smaller like a nail...checking on it i not have continuiti on ground aswell
