Acer nitro 5 bq24781 no acdrv
  • elsomer
    • 50
    • mexico
    Hi people, i have an acer nitro 5 with motherboard model gh51m la-k861p , it came with the resistor pr103 blow up, i repaced that resistor, i check the coils plb2, pl301, pl501 and has no short to ground, i conect the charger and it doesnt power at all, i check pqb3 on pin 5 to 8 and its 19v, pin 1 to 4 its 0
    so i repaced, pqb3, pqb4, and makes no change, still no acdrv, i replaced bq24781 and makes no change, still no acdrv, if someone can help pls, thanks, this are the schematic and boardview
    [MOD EDIT] LINK to schematic & boardview -> https://www.badcaps.net/forum/troubl...55-57-la-k861p
  • mon2
    • Dec 2019
    • 14335
    1) With no power to the board, measure the resistance (not diode mode) to ground of PQB4 (drain pins 5-6-7-8). Checking to see if the main power rail is shorted or not.
    2) Carefully, measure the voltage to ground on PUB1 for pins:
    (connect your power adapter)
    ACDET ; pin 6
    VCC ; pin 28
    REGN ; pin 24
    Post each measurement.
    • elsomer
      • 50
      • mexico
      Hi mon2, thanks for answer, pins 5 to 8 of pqb4 has no shorted rail here are the values of pub1
      acdet: 0v
      vcc : 19.5v
      regn : 0v
      • mon2
        • Dec 2019
        • 14335
        What is the voltage to ground of ADAPDET ?
        • elsomer
          • 50
          • mexico
          it has no shorted rail ,the value on resistance mode is 62kohm , im checking that value on cap pcb18
          • mon2
            • Dec 2019
            • 14335
            See attached. Need to review the mosfet gate voltage.
            • elsomer
              • 50
              • mexico
              Prb36 which is on the line adapdet is 5.8v and pin 1 on pqb11 is 5.8v
              • mon2
                • Dec 2019
                • 14335
                The ADAPDET pin on the DCin power adapter is not connected. When the power adapter is connected, this line should be LOW which will turn OFF PQB11. Once PQB11 is OFF, the ACDET voltage will be at the proper threshold > 2v7 and the charger IC should enable ACDRV.
                Test the theory by shorting PQB11 gate pin to ground. Summary - power adapter connector contact may be loose.
                • elsomer
                  • 50
                  • mexico
                  Test the theory by shorting PQB11 gate pin to ground, i did this and now acdet is 2.6v
                  • elsomer
                    • 50
                    • mexico
                    this means i need to replace pqb11?
                    • mon2
                      • Dec 2019
                      • 14335
                      No. Just connect a piece of wire between ground and the GATE pin on PQB11. Have the power adapter connected as well.
                      If the adapter is the proper one for this model, it will supply the ~19v.
                      OR
                      Flux and remove PQB11 for testing. This will allow for ACDET to return to a normal value. Confirm it.
                      • elsomer
                        • 50
                        • mexico
                        yeah, laptop is working perfect without the pqb11, do i need to replace it? or is there any risk of using the laptop without it?
                        • mon2
                          • Dec 2019
                          • 14335
                          The detection of the adapter is through this tiny circuit area we have reviewed today. Technically, if the power adapter is disconnected, then this ACDET voltage will also go to zero volts (since the voltage is based on the adapter voltage being lowered by the resistor based voltage divider) so from a quick review - yes, it is safe to leave it as-is. Perhaps wait on other techs to chime in for their view but looks ok to me.
                          • elsomer
                            • 50
                            • mexico
                            ok, thank you very much for help me , i learned a lot
                            • mon2
                              • Dec 2019
                              • 14335
                              You are quite welcome
                                ACER NITRO Nitro GX50-600 NITRO 50 i5-8400 Specification for Upgrade or Repair
                                This specification for the ACER NITRO Nitro GX50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro GX50-600 boardview and NITRO Nitro GX50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                09-12-2024, 03:28 PM
                                ACER NITRO Nitro N50-600 NITRO 50 i7-9700 Specification for Upgrade or Repair
                                This specification for the ACER NITRO Nitro N50-600 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the NITRO Nitro N50-600 boardview and NITRO Nitro N50-600 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                Acer Nitro Nitro 5 AN515-57-775V Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Nitro Nitro 5 AN515-57-775V Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Nitro 5 AN515-57-775V boardview and Nitro 5 AN515-57-775V schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-07-2024, 04:10 AM
                                Acer Nitro Acer Nitro 5 Black Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Nitro Acer Nitro 5 Black Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 Black boardview and Acer Nitro 5 Black schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) Notebook 5 Specification for Upgrade or Repair
                                This specification for the Acer Nitro Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full HD 144Hz, Windows 10, Black) boardview and Acer Nitro 5 AN515-57 15.6 inch Gaming Laptop - (Intel Core i7-11800H, 16GB, 1TB SSD, NVIDIA RTX 3070, Full...
                                09-07-2024, 03:10 AM
