problem with a Dell Latitude 7400 notebook
  • Markus1741
    • Sep 2020
    • 873
    • N/A
    Hello, maybe someone can help me.
    The following problem with a Dell Latitude 7400 notebook.
    ServiceTag: C5RBL13 Board number: LA-G871P Rev:1.0 (A00)
    It doesn't start and when I read the voltage on the USB-C port, it fluctuates around 0.8 watts.
    I measure it on the BIOS chip pin 8. It should be 3,3 volts.
    There are 3,3 volts but I can only measure 0.2 volts. (+3.3V_SPI)
    Is this the possibility that the PCH has a short circuit.
    Schematic - https://www.badcaps.net/forum/troubl...56#post1587856
    Thank you.
  • mon2
    • Dec 2019
    • 14545
    Review the voltage to ground of:
    DCIN_CHG (pin 17 on PU700)
    ADP (pin 16 on PU700)
    ACOK (pin 24 on PU700)
    PBAT_CHARGER_SMBDAT (pin 21 on PU700)
    PBAT_CHARGER_SMBCLK (pin 22 on PU700)
    • Markus1741
      • Sep 2020
      • 873
      • N/A
      Okay, here are the values ​​you want, thank you.​
      DCIN_CHG (pin 17 on PU700) = 19,73 volt
      ADP (pin 16 on PU700) = 19,60 volt
      ACOK (pin 24 on PU700) = 0,003 volt
      PBAT_CHARGER_SMBDAT (pin 21 on PU700) = 0,037 volt
      PBAT_CHARGER_SMBCLK (pin 22 on PU700) = 0,038 volt
      • mon2
        • Dec 2019
        • 14545
        Remove all power. Meter in resistance mode (not diode mode).
        Measure the resistance to ground of:
        +13.5VB - this is the main power rail for the logic board. Checking for a shorted component with the resistance check.
        +3.3V_ALW ; this rail is OFF as it can be observed with the ACOK / SMBDAT / SMBCLK lines being parked to a logic low - they need this rail to supply the pull-up voltage
        +5V_ALW
        The above rails will enable provided there is no short on each of the lines. Post each measurement.
        • Markus1741
          • Sep 2020
          • 873
          • N/A
          Sorry, there is no short circuit anywhere. No mosfet, no capacitor.
          • Markus1741
            • Sep 2020
            • 873
            • N/A
            Hello, I have +19.5V to PQ700 - AOE6936 then nothing, maybe 0.2V. I've already replaced the PQ700 Mosfet, no change.
            • Markus1741
              • Sep 2020
              • 873
              • N/A
              Measure the resistance across the following DCin mosfet pins of PQ700:
              D2/S1 = 53,1 k Ohm
              D1 = 143 k Ohm
              G2 = 10,7 M Ohm
              G1+S1/D1 = 146 k Ohm
              D1 = 53,1 k Ohm
                DELL Latitude 7400 Notebook 7000 Specification for Upgrade or Repair
                This specification for the DELL Latitude 7400 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 7400 boardview and 7400 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Latitude 7400...
                09-06-2024, 08:40 PM
                09-06-2024, 12:36 PM
