T480 with GeForce MX150 - not charging, no reaction to power button
  • sant1
    • May 2014
    • 11
    • Estonia
    MEC1653-BA1 pulled VCC3M down to 60ohm, replaced it, programmed with vertyanov, no reaction to on/off button and not charging now.
    Noticed that VSYS_OUT is 9.18V, had a opportunity to compare on UMA T480, it was 10.2V, no ideas if DGPU T480 should have same VSYS_OUT.​
  • sant1
    • May 2014
    • 11
    • Estonia
    Measured all BQ25700 pins, everything seems quite identical, compared with working board, attached picture with measurements.Only 3 different readings, VSYS, BATDRV# and SRP/SRN.
    Tried swapping BQ25700 - same result.
    No idea where to go, im randomly swapping components.
    • sant1
      • May 2014
      • 11
      • Estonia
      Forgot to add picture with the measurements. These measurements are without battery.
        NVIDIA GeForce RTX 3080 / RTX 3090 Schematic & Board View
        The GeForce RTX 3080 is an enthusiast-class graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA102 graphics processor, in its GA102-200-KD-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA102 graphics processor is a large chip with a die area of 628...
        10-02-2024, 08:52 AM
        NVIDIA GeForce RTX 2060 / RTX 2070 Schematic & Board View
        The GeForce RTX 2060 is a performance-segment graphics card by NVIDIA, launched on January 7th, 2019. Built on the 12 nm process, and based on the TU106 graphics processor, in its TU106-200A-KA-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 2060. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The TU106 graphics processor is a large chip with a die area of 445...
        10-02-2024, 07:51 AM
        NVIDIA GeForce GTX 950 / GTX 960 Schematic & Board View
        The GeForce GTX 950 was a mid-range graphics card by NVIDIA, launched on August 20th, 2015. Built on the 28 nm process, and based on the GM206 graphics processor, in its GM206-250-A1 variant, the card supports DirectX 12. This ensures that all modern games will run on GeForce GTX 950. The GM206 graphics processor is an average sized chip with a die area of 228 mm² and 2,940 million transistors. Unlike the fully unlocked GeForce GTX 960, which uses the same GPU but has all 1024 shaders enabled, NVIDIA has disabled some shading...
        10-01-2024, 01:54 PM
        NVIDIA GeForce RTX 4080 (RTX4080) Schematic & Board View
        The GeForce RTX 4080 is an enthusiast-class graphics card by NVIDIA, launched on September 20th, 2022. Built on the 5 nm process, and based on the AD103 graphics processor, in its AD103-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 4080. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The AD103 graphics processor is a large chip with a die area of 379 mm²...
        10-02-2024, 08:57 AM
        NVIDIA GeForce RTX 3070 Schematic & Board View
        The GeForce RTX 3070 is a high-end graphics card by NVIDIA, launched on September 1st, 2020. Built on the 8 nm process, and based on the GA104 graphics processor, in its GA104-300-A1 variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on GeForce RTX 3070. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The GA104 graphics processor is a large chip with a die area of 392 mm² and 17,400 million...
        10-02-2024, 08:48 AM
