Asus GL552VW Rev 2.0 don't post.
  • J_PH
    • Dec 2022
    • 37
    • Chile
    Greetings everyone,
    I would appreciate your help with the following issue:
    I have an Asus G552V notebook, Mainboard model GL552VW Rev 2.0 (Attached images), which upon powering on, does not display any video (Using the HDMI output with an external monitor as well) There is no disk reading, and it does not respond to the keyboard, except for the power button. Only the Power LED and the CAP LED light up.
    I have disconnected the battery, disks, and all peripherals to work only with the mainboard and start with the measurements.
    The RAM has been checked and is operational (I also replaced it with a working one).
    Both the CPU and the GPU heat up during testing, and the fan works correctly.
    Here's what I've done:
    Visual Inspection: No physically damaged components found.
    Voltage = Voltages are checked based on the schematic and the power-on sequence, which appears to be completed. All voltages are present, except +VCCGT.
    BIOS = 3 BIOS dumps are performed (BIOS desoldered and reprogrammed, ensuring correct writing). The obtained voltages are as follows:
    +1.0V_VCCST = 1.01V
    +1.0VSUS = 1.02V
    +1.0VSUS_VCCPRIM = 1.0V
    +12V = 13.93V
    +12VS = 13.92V
    +2.5V = 2.5V
    +3VA = 3.3V
    +3VA_DSW = 3.3V
    +3VA_EC = 3.3V
    +3VA_RTC = 3.08V
    +3VS = 3.36V
    +5VA = 5.09V
    +5VS = 5.1 V
    +FBVDDQ = 1.38V
    +NVVDD = 0.9V
    +PEX_VDD = 1.03V
    +RTCBAT = 0.46V
    +VCCCORE = 1.04V
    +VCCGT = 0V
    +VCCIO = 0.95V
    +VCCMPHYG = 1.2V
    +VCCPLL_OC = 1.22V
    +VCCSA = 1.12V
    +VCCSTG = 0.95V
    1.2V_PWRGD = 3.3V
    AC_BAT_SYS = 19.3V
    DDR_VTT_CTRL = 1.22V
    DDR4_DRAMRST = 1.22V
    DPWROK_EC = 3.3V
    IMVP8_PWRGD = 3.3V
    ME_AC_PRESENT = 3.3V
    PCH_SUSACK# = 3.3V
    PM_BATLOW# = 3.3V
    PM_PWRBTN# = 3.3V
    PM_RSMRST = 3.3V
    PM_SLP_SUS# = 3.3V
    PS_ON = 3.3V
    PWR_SW# = 3.3V
    RTCRST# = 3.07V
    SUSB_EC# = 3.3V
    SUSC_EC# = 3.3V
    SUSWARN# = 3.3V
    VCCST_PWRGD = 3.3V
    I'm feeling a bit disoriented regarding what to continue checking.
    Unfortunately, I don't have an oscilloscope to inspect other points.
    I've been thinking that it might be a dead CPU.
    I would appreciate it, based on your experiences, if you could tell me what else I could check, or if I should declare the equipment for spare parts.
    Thank you very much for your time.
    I've attached schematics and a boardview.
    https://www.badcaps.net/forum/troubl...52vw-schematic
  • J_PH
    • Dec 2022
    • 37
    • Chile
    Greetings to all, I have carried out a couple more tests, thinking that it could be a problem with the LCD backlight. I have obtained the following measurements.
    LCD_PWM_CON = 0V
    LCD_BACKEN_PCH = 0V
    LCD_BACKOFF# = 3.3V
    +3VS_LCD = 3.3V
    Could it be a chipset fault?
    • mon2
      • Dec 2019
      • 13832
      Review this one:
      +RTCBAT = 0.46V
      • J_PH
        • Dec 2022
        • 37
        • Chile
        Hello mon2, I have removed the CMOS battery since it is faulty; it has a voltage of 0.1V.
        As far as I understand, the equipment can work without any issues without the RTC Battery installed.
        Without the battery installed, the voltage of +RCTBAT starts at 0.46V, after 10 minutes it reaches and remains at 1.14V. (I am unsure why the voltage is increasing).
        The other voltages are stable:
        +3VA = 3.29V
        3VA_RTC = 3.07V.
        Thank you very much for your help; I will continue checking the equipment.
        If there is anything specific to look into, I would appreciate your input.
        Best regards,
        • mon2
          • Dec 2019
          • 13832
          Check D2001. Remove all power. Meter in diode mode. Measure each diode inside D2001 in diode mode. One direction should conduct and other direction should block.
            ASUS ROG GL552VW-DH71-HID4 Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-DH71-HID4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-DH71-HID4 boardview and GL552VW-DH71-HID4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:30 AM
            ASUS ROG GL552VW-DH71-HID1 Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-DH71-HID1 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-DH71-HID1 boardview and GL552VW-DH71-HID1 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 06:08 AM
            ASUS ROG GL552VW-CN444T Notebook Specification for Upgrade or Repair
            This specification for the ASUS ROG GL552VW-CN444T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the GL552VW-CN444T boardview and GL552VW-CN444T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
            09-06-2024, 05:30 AM
            ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook Specification for Upgrade or Repair
            This specification for the ASUS ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year boardview and ASUS E410MA-BV815TS 14.0 HD 1366x768 N4020 4GB 64GB with Office 365 1 Year schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively...
            09-07-2024, 02:50 AM
            ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
            This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
