Lenovo thinkpad L450 motherboard shorted
  • Rofix
    • Jul 2023
    • 73
    • Italia
    Hello everyone I have a problem on the motherboard of my ThinkPad Lenovo L450 there is a short circuit after the second mosfet on the main 19v power supply line, does anyone have the diagram for this board
    Motheboard is : AIVL1 NM-A351 Rev .1 .
    Thanks for the advice and help
  • mon2
    • Dec 2019
    • 14164
    Review the charger IC and the 2nd mosfet itself. Do you have REGN voltage? ACDRV voltage on the gate of the DCin mosfets?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      If you have short circuit after 2nd mosfet,then its wiser to measure the same on CLR and then proceed to desolder it and inject 1V/5A on the shorted side to find out what is shorted.
      • Rofix
        • Jul 2023
        • 73
        • Italia
        hi, on PU7 at pin 24 REGEN I find 6 Volt on pin 4 ACDRV the voltage fluctuates, it is around 0.150 Volt, on the gate of the main mofets PQ20/PQ21 the voltage varies around 0.150 Volt there too
        • mon2
          • Dec 2019
          • 14164
          Your 2nd DCin mosfet is probably defective so do review the advice in post # 3.
          Carefully, flux and remove the 4k resistor that is in series between ACDRV and the gate pins of the DCin mosfets. After this series resistor is removed (do not lose this resistor) - power up again and measure the voltage output @ ACDRV charger pin # 4.
          Is ACDRV now ~25 volts?
          • Rofix
            • Jul 2023
            • 73
            • Italia
            Hello i remove the 4k resistor but the voltage output @ ACDRV charger pin # 4. is 0 volt
            • mon2
              • Dec 2019
              • 14164
              Measure the voltage to ground very carefully of:
              ACDET ; must be > 2v4 to enable the dcin mosfets
              ACOK ; expected to be a logic low since main power rail is missing and this line is pulled to the missing +3VALW
              CMSRC ; used by the charger ic to create the boosted ACDRV voltage
              remove all power, meter in resistance mode. Measure the resistance to ground of the main power rail.
              Post each measurement.
              • Sephir0th
                • Oct 2020
                • 1282
                The main power rail is suspected of being short-circuited from the beginning with regard to the initial posting. I don't really understand why you're tinkering with the mosfets here instead.
                Proceed like advised from mcplslg123 already. Normally it is not even necessary to remove any component to find the faulty part with voltage injection.
                FairRepair on YouTube
                • Rofix
                  • Jul 2023
                  • 73
                  • Italia
                  hello
                  ACDET ; 2,4 Volt
                  ACOK ; 0.003 Volt
                  CMSRC ;0.006 Volt
                  resistance to ground of the main power rail after the second mosfet is 0,6 Ohm
                  • mon2
                    • Dec 2019
                    • 14164
                    Ok. As per post # 3, inject a 0v8 to 1v0 voltage onto the main power rail @ 3A-5A. We use a dedicated tool from Aliexpress (short killer) that spikes upto 30A of current. Often around 5A-8A the shorted part cracks / smokes open. Usually it is a shorted tantalum or ceramic cap. Hope it is the same for you. If you have a thermal camera, it will help to isolate the part. Be sure to check both sides of the PCB. If a high side mosfet is leaky on the board, it may have killed the CPU so do consider to remove the heatsink off the CPU for the heat inspection. First, just check around the board for a defective cap. You can use IPA (alcohol) to locate the defective part. Wherever the IPA evaporates, you have heat.
                    • Rofix
                      • Jul 2023
                      • 73
                      • Italia
                      Hi, while doing an injection I found this component that overheated a lot PU 10
                      • Sephir0th
                        • Oct 2020
                        • 1282
                        Something is odd. Why does the NM-A351 schematics, i sourced, does not fit to the Silk screen print?
                        However, from location this smells like 1.05V supply. A proper prayer that the coil does not measure below 10 Ohms and then replace the controller.
                        • Rofix
                          • Jul 2023
                          • 73
                          • Italia
                          You probably also found the AIVL2 NM-A351 Rev .1 schematic.
                          for my card I need the AIVL1 NM-A351 Rev .1.​
                          Unfortunately I also find 0 Ohm on the reel
                            Lenovo ThinkPad L450 Notebook L Specification for Upgrade or Repair
                            This specification for the Lenovo ThinkPad L450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the L450 boardview and L450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Lenovo ThinkPad...
                            09-06-2024, 05:30 AM
                            Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook X Specification for Upgrade or Repair
                            This specification for the Lenovo ThinkPad X1 Carbon + ThinkPad USB 3.0 Pro Dock Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X1 Carbon + ThinkPad USB 3.0 Pro Dock boardview and X1 Carbon + ThinkPad USB 3.0 Pro Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                            09-06-2024, 11:40 AM
