FX505DT No power
  • tommy97
    • Mar 2023
    • 160
    FX505DT No power
    Hi, I have problem with ASUS FX505DT, it was brought to me for no power, instant short on U8100 (TPS51225C), I've got replacement chip, nothing been changed (Chip warm up instantly after connecting the charger for up to 80C).I believe that +VDDCR_CPU_SOC or just low resistance 4ohm, (L8002 6.5Ohm to the ground, L8001 4.5Ohm to the ground, L8000 4.5Ohm to the ground), any advice what i should look for?
  • mon2
    • 14369
    This low resistance is ok for a cpu / gpu. Start with checking the usual dcin mosfets. Do review the sticky above on charger circuits by piernov.
    measure the voltage to ground of each mosfet pin.
    source (1-2-3)
    gate (4)
    drain (5-6-7-8)
    post each measurement. Also share the topside markings of these dcin mosfets and the charger ic. post pics of the area if not known.
    • piernov
      • Jan 2016
      • 4437
      • France
      No resistance to ground measurements on 3V/5V regulator?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        If U8100 is heating up,then very likely one of the LDO rail is shorted.Measure resistance to GND on 3V LDO and 5V LDO. No power attached.
        • tommy97
          • Mar 2023
          • 160
          Q8801&Q8802 - Gate 24V, Source & drain 19V (SM4511 Both) mon2
          5V_LX 0.24v 3V_LX Missing, 5VA Missing, 3VA &+RTC POWER Missing
          Q8100 - Drain and source 19V - Gate missing
          U8100 Resistance to the GND: piernov , mcplslg123
          1:180K
          2.9K
          3.5Ohm
          4..1oh
          5.0.7ohm
          6.10k
          7.100k
          8.5k
          9.2Mohm
          10.128k
          11..135k
          12.1.2ohm
          13.414k
          14. 15k
          15.137k
          16.145k
          17. ol
          18.15k
          19.3.3Ohm
          20.10k
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Pin3 is for VREG3 aka 3V LDO and is clearly shorted to GND. You need to inject voltage(1V/5A) and see if anything is getting hot. Very very likely your SIO is shorted.
            • tommy97
              • Mar 2023
              • 160
              mcplslg123 you were right, short lead to KBC (IT8987e), i've replaced it (spare from the old board), laptop power up/charge battery, however it does not display, keyboard backlight is on, react for pwr button, sometimes HDD light flash once, sometimes restarting. mon2?
              It draw 0.55amp without battery and 2.4amp with the battery attached.
              • mon2
                • 14369
                What are the voltage to ground readings for the charger IC @ U8800A for:
                ACOK
                ACDRV
                ACDET
                • tommy97
                  • Mar 2023
                  • 160
                  ACDRV - 24.5v
                  ACDET 2.65v
                  ACOK​ - 3.1V (5th leg)
                  mon2
                  • mon2
                    • 14369
                    These are good measurements to enable the DCin mosfets (Q8801 / Q8802).
                    Confirm the voltage to ground of the DCin mosfets @ Q8801 and Q8802. Is the voltage stable @ drain pins 5-6-7-8 of Q8802?
                    • tommy97
                      • Mar 2023
                      • 160
                      Everything look in order 19.5v on Source and Drain, Gate 24.5v, i've just checked how it does power without the LCD connected and it seem to work, it goes to 1.2amp with no battery cpu & gpu gets hot, does not restart, fan spin. Where when connected LCD laptop goes to 0.50amp and restarting 3-6 times and then standby on 0.50amp no fan spin, checked on known tested lcd, same problem.
                      mon2
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        IT8987E is programmable SIO.Since you got the SIO from another board,the EC firmware wont match. You need to program this SIO first with a SIO programmer like SVOD etc.
                        However, if you dont own a SIO programmer,then order a new blank SIO and solder it.It'll flash itself on first boot.
                        • tommy97
                          • Mar 2023
                          • 160
                          mcplslg123 thanks for your answer, I was thinking that it might be the case... I'll keep the post updated when I get the part.
                          • G. Sling
                            • Nov 2024
                            • US
                            Which boardview file did you use for FX505DT. Looked around cant seem to find one.
                              ASUS TUF Gaming FX505DT-HN766T Notebook Specification for Upgrade or Repair
                              This specification for the ASUS TUF Gaming FX505DT-HN766T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN766T boardview and FX505DT-HN766T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-07-2024, 12:10 AM
                              ASUS TUF Gaming FX505DT-HN630T Notebook Specification for Upgrade or Repair
                              This specification for the ASUS TUF Gaming FX505DT-HN630T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN630T boardview and FX505DT-HN630T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              09-06-2024, 10:50 PM
                              ASUS TUF Gaming FX505DT-HN536T Notebook Specification for Upgrade or Repair
                              This specification for the ASUS TUF Gaming FX505DT-HN536T Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN536T boardview and FX505DT-HN536T schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                              ASUS TUF Gaming FX505DT-HN450 Notebook Specification for Upgrade or Repair
                              This specification for the ASUS TUF Gaming FX505DT-HN450 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-HN450 boardview and FX505DT-HN450 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 10:00 PM
                              ASUS TUF Gaming FX505DT-BQ236 Notebook Specification for Upgrade or Repair
                              This specification for the ASUS TUF Gaming FX505DT-BQ236 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the FX505DT-BQ236 boardview and FX505DT-BQ236 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                              09-06-2024, 09:10 PM
