HP Zbook 15 G4 LA-E161P NO POWER
  • madjid911
    • 410
    • France
    I have an HP Zbook 15 G4 (LA-E161P motherboard) which does not start, there was a short on a capacitor supplied with 3V, I replaced it, no short now, I found the 3v voltage but it doesn't start.
    When I plug in the charger, the LEDs flash all the time, when I press the power button the LEDs stop flashing, I saw a post from someone who had the same problem and who had reprogrammed the bios and EC, I tried I reprogrammed everything but the result remains the same, I also changed the SIO chip if ever it was defective, and the 3V chip, but nothing changes.
    Do you have an idea ? THANK YOU
  • jasko_jacker
    • Oct 2014
    • 1140
    • italy
    It seems that the schematic and the boardview does not exist. How did you reprogram the system, does it have a dedicated chip or did you use a cable and a programmer? Are you sure you are using a working bios and ec firmware? Check all the soldering on the chip you replaced and see if you can extract the bios from the manufacturer's site
    • madjid911
      • 410
      • France
      I unsoldered the EC and MAIN eeprom chip, reprogrammed with xgecu t56, I am sure of my soldering, I checked everything, also the soldering of the micro controller. I took the EC and MAIN dumps from this site badcaps
      Last edited by SMDFlea; 12-19-2023, 05:14 PM. Reason: bios deleted,this isn`t the bios requests sub forum
        • 21853
        Reminder: rules and organization of this section
        https://www.badcaps.net/forum/troubl...f-this-section
        • acedogblast
          by acedogblast
          11-02-2024, 05:13 PM
          Common SPI bios chip programming Questions and Answers
          by SMDFlea
          Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
          A: If you can`t read from it how do you expect to write to it ?.
          Q: Why is my bios chip unreadable ?.
          A: The programmer is faulty or has a worn or broken zif socket.
          The USB cable is frayed,connector pins worn or some other physical damage.
          Not enough amperage or voltage to power the programmer properly.
          Bad...
          09-02-2021, 04:40 PM
          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
          09-07-2024, 05:20 AM
