Acer Aspire D270 dead
  • corell
    • 16
    • philippines
    Any one here have a schematic diagram for this Model? i found a open picofuse but still no power or anything. any suggestion where to check.. i'm newbie in laptop repair. thanks in advance..
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    Re: Acer Aspire D270 dead
    kabayan,
    check this out...
    • corell
      • 16
      • philippines
      Originally posted by fddizon
      kabayan,
      check this out...
      thnks sir fddizon.. pagpalain ka kabayan
      • sasser
        • Dec 2012
        • 365
        • Malaysia
        usually if no 19v what item is failed? mosfet or caps? and if no 3.3v what component failed then how about no 5v on motherboard?
        • fddizon
          • Sep 2011
          • 555
          • Philippines
          if there is no 5v but have 3.3v, check output upper and lower fets and gate signals of these fets. if no signal on gate replace regulator
          • corell
            • 16
            • philippines
            Sir dizon, if UGATE is 0.2V of ISL88731C, so no gate input to AON7410.. It is considered as defective? There's a 19V in CSSN of ISL88731C..
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              Check if it turn on with battery . I got two of this model and it only power on with charged baterry . Solved issue by reflowing special area on the board(not the chipset).
              • spidey
                climbs
                • Dec 2012
                • 644
                • Cyprus
                what do you mean with "speacial area" ?
                • degutji
                  • Dec 2012
                  • 173
                  • Indonesia
                  My opinion, "special area" is a secret area that only she knew it, and did not want to share with us
                  • corell
                    • 16
                    • philippines
                    I replaced the ISL88731C and there's a output now.. but another problem occurred.. there's no 5V and 3V output in voltage controller IC RT8223M.. there's no supply to the gate of MOSFETs.. VIN of RT8223M is 3.3V.. any idea? thnks in advance..
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      hi spidey . the special area is just around rt8223.
                      • dycc
                        Vision
                        • Nov 2011
                        • 625
                        • Côte d'Ivoire
                        corell check pr190 resistor
                        • corell
                          • 16
                          • philippines
                          thnks for the reply..I already checked that sir.. 19V input of PR190.. output is 3.3V to VIN of RT8233M.. i checked the PR190 its 114 ohms.. labeled at 100 ohms.. it is ok? 19V became 3.3V after the PR190?
                          • dycc
                            Vision
                            • Nov 2011
                            • 625
                            • Côte d'Ivoire
                            pr190=10ohms not 100ohms
                            ij you find 114ohms so it's dead
                            • dycc
                              Vision
                              • Nov 2011
                              • 625
                              • Côte d'Ivoire
                              100= 10 * 10^0 = 10 *1 =10 ohms
                              • corell
                                • 16
                                • philippines
                                thanks for the clarification sir..
                                • corell
                                  • 16
                                  • philippines
                                  after replacing the PR190, still no 3V and 5V output from RT8223M.. any idea? is RT8223M is defective? thnks in advance.
                                  • whaldsz
                                    • Apr 2013
                                    • 395
                                    • Philippines
                                    Please post the voltage reading of all pins of PU3 - RT8223m
                                    • corell
                                      • 16
                                      • philippines
                                      i'll pose later.. thnks sir..
                                      • corell
                                        • 16
                                        • philippines
                                        pin 13 - 6.21V
                                        pin 16 - 19.14V
                                        all remaining pin - 0V
                                          ACER Aspire Aspire E560 Aspire E6400 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E560 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E560 boardview and Aspire Aspire E560 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:28 PM
                                          ACER Aspire Aspire E700 Aspire E6300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire E700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire E700 boardview and Aspire Aspire E700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 02:30 PM
                                          ACER Aspire Aspire M7711 Aspire Q9300 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire M7711 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire M7711 boardview and Aspire Aspire M7711 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                                          09-06-2024, 05:27 AM
                                          ACER Aspire Aspire G7200 Predator Defender Aspire 9750 Specification for Upgrade or Repair
                                          This specification for the ACER Aspire Aspire G7200 Predator Defender can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire G7200 Predator Defender boardview and Aspire Aspire G7200 Predator Defender schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
