Compaq CQ41 no display
  • fddizon
    • Sep 2011
    • 555
    • Philippines
    hi,
    i need schematic of LA-4117P REV. 1.0
    searched the web to no avail (no free download)
    thanks
  • alihomee
    • Dec 2012
    • 1570
    • malaysia
    Re: Compaq CQ41 no display
    your cq41 got power or not
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      it has power. after a mild reflow, laptop turns off after few seconds
      found one close...
      btw, have worked on the same model?
      • sasser
        • Dec 2012
        • 364
        • Malaysia
        compaq cq41 if no display always problem with ati 216-072001 chip. please replace if u failed to reflow.
        • alihomee
          • Dec 2012
          • 1570
          • malaysia
          then sure a gpu problem
          • klangsotan
            • Mar 2014
            • 45
            • indonesia
            hi master can you help me
            hp compact cq41 kode board nal70 la -4106p
            power is on but not display
            thanks
            • banchi99
              • Jul 2015
              • 107
              • U.S.A
              there two way to solve you problem. soft and hard. Soft way first check Ram,Proccesor and video chip last bios. For the last step you need a Bios programmer. Hard way you have to check all voltage rails.
              • klangsotan
                • Mar 2014
                • 45
                • indonesia
                thanks for your sharing i was found must be 1.5 VP on schematic but that is 8 volt is that failure consumtion voltage on PL 401 ?
                • banchi99
                  • Jul 2015
                  • 107
                  • U.S.A
                  pq401
                  pin 5 6 7 8 = 18.5 volts
                  pin 1 2 3 = 1.8 vols
                  you have to check 18.5 rail for a shortcircut
                  • klangsotan
                    • Mar 2014
                    • 45
                    • indonesia
                    pq401
                    i was check for pq401 if power on
                    but
                    pin 1 2 3 = 10.9 volt
                    pin 4 = 10.6 volt
                    i was check for pq401 if power of
                    but
                    pin 1 2 3 = 0 volt
                    pin 4 = 0 volt
                    • banchi99
                      • Jul 2015
                      • 107
                      • U.S.A
                      Do you have on pin 4,10 ,+5ALWAY ?. Pin 1 EN .. this signal from I/O EC controller enabled PU 401 if all of is correct. Check EC controller voltage and bios
                      • klangsotan
                        • Mar 2014
                        • 45
                        • indonesia
                        i was check PU401 POWER OFF
                        PIN 4 , 10 = +5 VOLT
                        KEEP SHARING MASTER
                        STILL NO DISPLAY
                        • banchi99
                          • Jul 2015
                          • 107
                          • U.S.A
                          http://www.instructables.com/id/How-...ansistor-Work/
                          • banchi99
                            • Jul 2015
                            • 107
                            • U.S.A
                            lift up oq401 and check it. Also what you need is the TPS51117 datasheet
                            • klangsotan
                              • Mar 2014
                              • 45
                              • indonesia
                              thank's you for this link sir
                              • OopManthai
                                • Dec 2015
                                • dsfsdfsfd
                                thank you
