No display Samsung R580 Nec Tokin maybe?
  • tomodachi
    • Apr 2012
    • 610
    • Turkey
    Hi guys,
    Laptop starts up normally but no display, I m pretty sure this is not relate to GPU or a chipset problem
    There is a nec tokin (OE687) next to the CPU socket which looked suspect to me, is there anyone saw this problem before ?
  • spidey
    climbs
    • Dec 2012
    • 644
    • Cyprus
    Re: No display Samsung R580 Nec Tokin maybe?
    start measuring VCORE voltage first, if you suspected NEC/TOCIN. With the given information, i cannot tell you anything. you should start measuring primary and secondary voltage supplies, if voltages ok, reprogram bios chip. check xtals with scope, then you may reflow.
    good luck.
    • tomodachi
      • Apr 2012
      • 610
      • Turkey
      good luck.
      Thanks for the tip Spidey, let s see what I can do
      • tomodachi
        • Apr 2012
        • 610
        • Turkey
        after one day of struggle I find out the LVDS cable is disconnected from LED screen because they forgot to put tape on LVDS socket.
        so the mobo is ok, thanx..
