New Members
Please consider donating to this site if it has helped you. We rely on these donations.
Please also introduce yourself here Introduce yourself here.
And finally, Read the Forum rules here.
Never tried it on motherboards but i have on high voltage stuff. Come to think of it i think ill borrow the camera from work this weekend and try it out on a board i have thats acting up.
Won't find something good under 6-800$ ... and not sure how much one would help you in diagnosing motherboards, considering the boards are 6-10 layers with lots of copper to dissipate the heat.
Flukes are about 1000-1400$, the cheapest... which would probably not give you enough resolution... see http://www.ticameras.co.uk/flir-i3-1.html .. 60x60 pixels...
It would probably make more sense to get a good multimeter, with 50.000 counts or something like that, so that you could spot minute differences in the resistance on the traces to spot what's shorted or partially shorted..
It uses a single infrared sensor, like the text says. At 2-3 meters distance the spot the sensor "measures" is a circle of about 20-40 cm wide.
The camera would make a reasonable image of your room because the servo would move the sensor at various angles and the processor inside would take lots of measurements and merge them to generate each "pixel" in the image.
However, such camera would not have enough precision to generate an image of something close to the camera, like 20-50cm away from camera, it wouldn't work.
Just look at the pictures and the distance the pictures are made from, and how rough the heat map is, you can basically see the "pixels". You wouldn't be able to determine what particular IC on a motherboard is hotter than the rest, it's not that accurate/precise.
This specification for the HP ProBook 430 G7 + Pan/Tilt Home Security Wi-Fi Camera Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Pan/Tilt Home Security Wi-Fi Camera boardview and 430 G7 + Pan/Tilt Home Security Wi-Fi Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
This specification for the HP EliteBook 830 G5 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Image Load & Asset Tag boardview and 830 G5 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
This specification for the HP EliteBook 830 G5 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G5 + Image Load, Asset Tag & Testntag boardview and 830 G5 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
Hello, i found this thermal camera on the ALiExpress and i wanted to ask if anybody use this for electronic repair. Is it any good, and do i need to have macro lens since i don't see that this camera has it.
It cost around 180€-190€.
If someone can recommend something similar under 200€ I would appreciate it.
I haven't been able to find a schematic or board view for one of these out in the wild. I had one come in with a no charge/no boot issue.
It Uses two pairs of Source to Source Mosfets after the power jack to prevent back flow from battery or PSU after the power jack.
The drain on the board feed side of the Mosfets measures a near dead short to ground. I attempted a voltage injection there it draws about 1.4A at 1V absolutely nothing heats up on the thermal camera.
It draws 1.86A injecting directly to ground.
