HP Pavilion dm3 would not powering on
  • alihomee
    • Dec 2012
    • 1596
    • malaysia
    i have a book with power problem. its model is hp pavilion dm3-1109tu. When i plug in the led near power jeck lights up but when i push power switch it does not comes on. i also try with battery and dc power but nothing change.i need some help
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: HP Pavilion dm3 would not powering on
    Could be a short circuit, or, most likely, a bad solder joint. HP laptops of a certain era had lots of problems with nvidia graphics chips going bad, or the solder joints on them going bad.
    Muh-soggy-knee
    • alihomee
      • Dec 2012
      • 1596
      • malaysia
      so what should i do
      • DerStrom8
        Techie
        • Dec 2012
        • 76
        Do any of the lights come on at all (HDD, wifi, volume, etc) when you hit the power button? If they do, then it's most likely a problem with the video card. It's a very common problem among HP laptops, especially. The microscopic solder joints crack and there is no longer a good connection, and the display is partial, or even just goes black. I have one that did that.
        If none of the lights come on whatsoever, then it's probably not a problem with your video card. It's probably a short somewhere, as Ben7 said.
        Good luck!
        Matt
        • alihomee
          • Dec 2012
          • 1596
          • malaysia
          no light comes on.Only the led near power jack lights up
          • bobbyg0001
            Bob
            • Jun 2011
            • 5
            This model has an Intel chip. You should try another power button switch.
            • opamp
              • Dec 2012
              • 160
              • united states
              Check for 3.3v on power button pin 1 then check pin 3 while your pressing the power button it should drop to zero volts.
