acer aspire 2920 display crash
  • alihomee
    • Dec 2012
    • 1577
    • malaysia
    hello all i have a acer aspire 2920 with vary strange problem when i try to load windows its display crashes or divieded into lines and notebook hangs and some time restarts help me please
  • kasatmata
    • Sep 2012
    • 18
    • Indonesia
    Re: acer aspire 2920 display crash
    please check the voltage at the NEC / Tokin
    • fddizon
      • Sep 2011
      • 555
      • Philippines
      reflow vga chip
      • ws3c
        • Dec 2012
        • taiwan
        the cpu below nec capacitance changed to 330 * 6 ok
        • valiant007
          Comp Technician
          • Dec 2012
          • 44
          • philippines
          if you have a spare screen i would suggest replacing your screen. does it work with an external monitor?
          _________________________________________________________________
          Free Computer Service!!!!!!!!!
          If We can´t Fix the problem.
          • kasatmata
            • Sep 2012
            • 18
            • Indonesia
            vcore problem
            • Engineer2k2
              • Aug 2009
              • 5
              If the issue is present while using an external monitor as suggested by valiant007 then just
              Replace the RAM with other tested (or New) from other Laptop. I had encountered similar problem sometime back with a bad RAM.
              • tujuhkalitujuh
                • Oct 2013
                • 27
                • Indonesia
                2920 appears to be have problem with its vcore, replacing NEC TOKINS 0907 would have been the solution, if it is stand still then you better check on North Bridge/GPU Chip. but it seems so rare case for 2920 had problems with the GPU chip. Every laptops almost have the same pattern symptomps on each batch.
                • robrock1
                  • Jul 2013
                  • 129
                  • Ghana
                  resolder cpu power ic
