AMD RadeOn IGP BGA Cold Joints
  • lord
    • May 2011
    • 319
    • Croatia
    Hi there,
    I have a question regarding reballing the small AMD RadeOn IGP BGA. Everytime i clean the board i rip of some of the pins. So i decided not to remove the BGA, i just do a reflow, but the problem is that this works only for a limited amount of time.
    Does any of you have expirience with this chipsets?
    Regards from Croatia,
    Darko
  • lord
    • May 2011
    • 319
    • Croatia
    Re: AMD RadeOn IGP BGA Cold Joints
    Nobody knows? Is there a member who deals with reballing and reflow?
    • mattbrad2
      • Jan 2011
      • 122
      I"m starting to have a TON of these AMD chips needing to be reballed. It's almost as bad as the HP DV problem a few years ago, except this time its not just one manufacturer. Sorry to tell you though, you'll have to take the plunge and continue to master the craft of reballing. The #1 problem with lifted pads is not enough heat from the bottom of the board. My rework station is a tri-zone and the nozzle at the bottom is set to 265C (the temp of the hot air, not the board temp). Soak the board first from the bottom (about 3-5 minutes will do) before starting your upper nozzle. Using two thermocouplers, I lift the chip at 230C. Occasionally I'll still get a lifted pad but I'd say only one out of 10.
      • lord
        • May 2011
        • 319
        • Croatia
        I don't know if you understood me. I lift the pads when cleaning the board, not when removing th BGA. Mine procedure looks like this:
        1. I insert the flux under the BGA
        2. I preheat the board to 180°C
        3. I turn on the IR heater and when the BGA balls are melted (i touch the chip by its side and it moves)
        4. i pick up the BGA with vacuum tweezers
        5. I put new flux on the board and pick the rest of the solder with my soldering iron
        6. Using the copper wire (don't know what's it called), a remove the rest of the solder and at this point - when going through the pads with the wire i lift them up, and it douesn't make any difference how carefull and gentle i am
        • mattbrad2
          • Jan 2011
          • 122
          I see. I've had the same issues. I switched flux and the problem went away. I had some cheap (fake) Kingbo. Went out and spent some money on the genuine stuff and its amazing what a difference its been.
          • lord
            • May 2011
            • 319
            • Croatia
            I am using AMTECH NC-559-UV no clean. Now i am about to ran out and i bought BURNLEY DM-200, but i didn't try it yet.
            Thanks for the tip.
              AMD Radeon R9 290 / R9 380 / R9 390 Schematic & Board View
              The Radeon R9 290 was a high-end graphics card by AMD, launched on November 5th, 2013. Built on the 28 nm process, and based on the Hawaii graphics processor, in its Hawaii PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon R9 290. The Hawaii graphics processor is a large chip with a die area of 438 mm² and 6,200 million transistors. Unlike the fully unlocked Radeon R9 290X, which uses the same GPU but has all 2816 shaders enabled, AMD has disabled some shading units on the Radeon R9 290 to reach the...
              10-01-2024, 12:46 PM
              AMD Radeon RX Vega 56 / RX Vega 64 Schematic & Board View
              The Radeon RX Vega 56 is a high-end graphics card by AMD, launched on August 14th, 2017. Built on the 14 nm process, and based on the Vega 10 graphics processor, in its Vega 10 XL variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX Vega 56. The Vega 10 graphics processor is a large chip with a die area of 495 mm² and 12,500 million transistors. Unlike the fully unlocked Radeon RX Vega 64, which uses the same GPU but has all 4096 shaders enabled, AMD has disabled some shading...
              10-01-2024, 01:07 PM
              AMD Radeon RX 470 / RX 580 Schematic & Board View
              The Radeon RX 470 is a mid-range graphics card by AMD, launched on August 4th, 2016. Built on the 14 nm process, and based on the Ellesmere graphics processor, in its Polaris 10 PRO variant, the card supports DirectX 12. This ensures that all modern games will run on Radeon RX 470. The Ellesmere graphics processor is an average sized chip with a die area of 232 mm² and 5,700 million transistors. Unlike the fully unlocked Radeon RX 480, which uses the same GPU but has all 2304 shaders enabled, AMD has disabled some shading units...
              10-01-2024, 12:52 PM
              AMD Radeon R7 340 / R7 430 Schematic & Board View
              The Radeon R7 340 OEM was a graphics card by AMD, launched on May 5th, 2015. Built on the 28 nm process, and based on the Oland graphics processor, the card supports DirectX 12. Even though it supports DirectX 12, the feature level is only 11_1, which can be problematic with newer DirectX 12 titles. The Oland graphics processor is a relatively small chip with a die area of only 77 mm² and 950 million transistors. It features 384 shading units, 24 texture mapping units, and 8 ROPs. AMD has paired 2,048 MB GDDR5 memory with the...
              10-01-2024, 12:36 PM
              AMD Radeon RX 7900 XT (RX7900XT) Schematic & Board View
              The Radeon RX 7900 XT is an enthusiast-class graphics card by AMD, launched on November 3rd, 2022. Built on the 5 nm process, and based on the Navi 31 graphics processor, in its Navi 31 XT variant, the card supports DirectX 12 Ultimate. This ensures that all modern games will run on Radeon RX 7900 XT. Additionally, the DirectX 12 Ultimate capability guarantees support for hardware-raytracing, variable-rate shading and more, in upcoming video games. The Navi 31 graphics processor is a large chip with a die area of 529 mm²...
              10-01-2024, 12:20 PM
