Surface laptop 3 charging problem
  • arashmoayyedizadeh
    • Jan 2022
    • 61
    • Iran
    Hello dear experts
    I have a surface laptop 3 that doesnt charge the battery or turn on with adapter
    Only turns on with battery
    I was working on charging circuit and noticed that chgr_ok pinof bq25713 is fluctuating between 1.4 and 1.7 volts
    It should be 1.8 volts because its pulled up to 1.8v by a 200k resistor
    The strange thing is if i inject 1.8 volts or jump the pullup resistorfor a second it will start charging and works perfect
    If i disconnect the charger and reconnect it i should inject or jump again
    Any idea?
    There is no other component there
    Only charging ic , io and pullup resistor
  • mon2
    • 14664
    Re: Surface laptop 3 charging problem
    In general, do not jump or inject till more is known about the circuit and possible issues.
    What is the history of the unit?
    With care, measure the voltage of the pull-up side of the resistor that is mated to 1v8. What is the voltage? Is it a stable 1v8?
    If not, that is of concern.
    Next, remove all power. Meter in resistance mode. Measure the resistance to ground of this signal chgr_ok.
    This signal is open-drain. This means the charger IC will be able to pull-down the signal but for a logic high ('1'); the line is open or floating. For this reason, the 200k resistor must be present to pull up this floating line to the soft logic high value.
    If the pull-up voltage is stable @ 1v8 and this signal is fluctuating then the charger IC is believing the voltage in from the adapter is not stable or it is also fluctuating. Confirm if the adapter is suitable for this laptop. Confirm if this voltage is stable while attached to this laptop.
    • coasterghost
      Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
      by coasterghost
      For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
      Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
      Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
      System Hardware:
      Processor: AMD Ryzen 7 PRO 5850U
      Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
      09-08-2025, 10:46 PM
      Microsoft Surface Laptop Surface Notebook 5 Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop Surface Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface boardview and Surface schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-07-2024, 06:21 AM
      Microsoft Surface Surface Go 3 Go 3 Specification for Upgrade or Repair
      This specification for the Microsoft Surface Surface Go 3 can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Go 3 boardview and Surface Go 3 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for...
      09-07-2024, 04:10 AM
      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
      09-07-2024, 01:00 AM
      Microsoft Surface Laptop Surface Laptop 4 Notebook Specification for Upgrade or Repair
      09-07-2024, 12:40 AM
