HP Pavilion 14-ce3514sa G7AL-2G DAG7ALMB8C0 REV: C diagnostics
  • Swell61
    • Oct 2023
    • 31
    Hiya
    I found a faulty HP Pavillion 14-ce3514sa am having a stab at repairing it.
    Motherboard is G7AL-2G DAG7ALMB8C0 REV: C
    The board doesn't boot when the power button is pressed. The charger LED comes on when it is plugged in and when the power button is pressed, the main voltages are present on the board, the fan spins and the power LED comes on, but there's nothing on the screen (neither the built in one nor the HDMI out) and the keyboard doesn't light up.
    The first and possibly only thing concerning now is VCCIN for the CPU. After the board has been powered on for 30-60 seconds, the CPU heats up quite a lot, and the two output regulators(? not sure that's what they are) get *very* hot, to the point where I can't touch them for more than a second or two. I measured 1.8V at the power supply output for the CPU and (I'm not sure this is relevant) I measure around 80ohms from VCCIN to ground. I had a dig through Intel's datasheet for 10th gen CPUs, and, if I'm understanding it correctly, the voltage should not exceed 1.52V.
    Where I've measured is the output of the two things in green boxes at the top in this photo from another post about this motherboard on this forum (the bottom green box for the DRAM measures the correct 1.2V).
    Does this mean that the CPU has been waaaaay overvolted and is now toast? I've found one other case of this motherboard with this issue online but the poster didn't update with what the problem ended up being.
    Edit: Attached screenshot from the datasheet. It's from Intel doc number: 615211-008
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: HP Pavilion 14-ce3514sa G7AL-2G DAG7ALMB8C0 REV: C diagnostics
    Incorrect datasheet. Core i5-1035G1 is from Ice Lake family and that has FIVR.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      1.8V at Vcore is correct for 10th/11th gen cpu.Absolutely sure.
      • Swell61
        • Oct 2023
        • 31
        Ah, well that's good news! Thank you both
        I shall continue diagnostics later. I've only got as far as checking the main voltages so far. Are they any "check this first" tips you can give for this sort of motherboard? I'll be trying to follow through with the schematics.
        I appreciate the help
        Edit: Oh and does the 80ohms mean anything?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          80 Ohms is fine. Check whether DRAMRST# is present on pin108 of ram slot.Make a backup of your existing bios and flash known good clean me bios.
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Another thing i recommend is to replace the vcore coils with marking R15 or R22. Measure voltage on vcore rail again and very likely you'll get 1.5-1.6V instead of 1.8V and system will be relatively cooler. Wierd but works on 10th gen onwards.
            • Swell61
              • Oct 2023
              • 31
              New BIOS didn't seem to change anything.
              For DRAMRST, when I power on the board, it goes to about 100mV for around 8 seconds, and then it goes up to 1.2V.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                DRAMRST# is fine too.
                • Swell61
                  • Oct 2023
                  • 31
                  Ok. Is there anything else you think I should check? I put a logic analyser on the BIOS flash chip and there's some activity when the board is powered on, though I can't tell what it is doing because the logic analyzer sample frequency isn't high enough.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Have you replaced the coils i suggested?
                    • Swell61
                      • Oct 2023
                      • 31
                      Ah, no, I thought that was something I could do after I confirmed it was working, I didn't realise it was part of troubleshooting. I shall order some replacement coils
                      • Swell61
                        • Oct 2023
                        • 31
                        I haven't managed to find any of the correct specification in small quantities without insane shipping prices yet. Would it be possible to continue troubleshooting without swapping them and then swap them once it is known working?
                        • Swell61
                          • Oct 2023
                          • 31
                          Update: I found some gunk (looks like a sticker) in the RAM slot on one end that looked like it was preventing proper contact with the DIMM (it could have been shorting the pins, I didn't check before I cleaned it). I've cleaned it all out and now the RAM and CPU voltages have gone when I power it on, they're both 0. I can hear coil whine when I turn it on now. It seems that my symptoms now match those from the thread I used the picture from - https://www.badcaps.net/forum/showthread.php?p=1233066
                          Update on the update: Old behaviour is back, voltages are back and the CPU and coils are getting hot
                          • Swell61
                            • Oct 2023
                            • 31
                            It's something to do with the RAM slot. I just pressed a lot of weight on it with my hand and powered it on, and I got a screen about the CMOS battery being disconnected out of the HDMI port
                            • reformatt
                              • Feb 2020
                              • 1520
                              Check for loose pins at each end of the DIMM slot. Usually its on the inner row that pins are loose and need resoldering. I just use the nose of my tweezers to nudge each pin to see if they move. Seen this on a few models now.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Very common with newer HP'S specially.
                                • Swell61
                                  • Oct 2023
                                  • 31
                                  I've resoldered all of the pins on the DIMM slot. The board booted a couple of times but it had the intermittent no RAM or VCCIN voltage problem. Now it has that problem consistently and doesn't boot at all. Something isn't turning on those power rails
                                  • Swell61
                                    • Oct 2023
                                    • 31
                                    Following the request on the other thread, I've measure the pins on PU4 (schematic) / PU8300 (boardview) / PU12 (other thread) - the RT8231BGQW for the RAM:
                                    Pin 4 (VTTREF): 0V
                                    Pin 7 (1P35V_S3/MAINON): 0V
                                    Pin 8 (1P35V_S5): 0V
                                    Pin 9 (1P35VTON): 18.9V
                                    Pin 11 (1P35_VID): 5.1V
                                    Pin 12 (+5VS5): 5.1V
                                    I'm not sure where to measure VCCSA/PCHPOWER. PCH_PWROK is 0V and VCCIN_AUX (not on the schematic but is in boardview) is also 0V. RSMRST is 3.3V.
                                      HP Pavilion Pavilion p6560be-m Desktop PC Bundle Pavilion p6500 E6600 Specification for Upgrade or Repair
                                      This specification for the HP Pavilion Pavilion p6560be-m Desktop PC Bundle can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion p6560be-m Desktop PC Bundle boardview and Pavilion Pavilion p6560be-m Desktop PC Bundle schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                      09-12-2024, 03:44 PM
                                      HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) Pavilion 550 i5-6400 Specification for Upgrade or Repair
                                      This specification for the HP Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) boardview and Pavilion Pavilion Desktop - 550-257na (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                      HP Pavilion Pavilion Desktop - 570-a079w Pavilion 570 J4205 Specification for Upgrade or Repair
                                      This specification for the HP Pavilion Pavilion Desktop - 570-a079w can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-a079w boardview and Pavilion Pavilion Desktop - 570-a079w schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer...
                                      HP Pavilion Pavilion Desktop - 570-p056 Pavilion 570 i7-7700 Specification for Upgrade or Repair
                                      This specification for the HP Pavilion Pavilion Desktop - 570-p056 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Pavilion Desktop - 570-p056 boardview and Pavilion Pavilion Desktop - 570-p056 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                      HP Pavilion Wave Pavilion Wave Desktop - 600-a030na Pavilion Wave i3-6100T Specification for Upgrade or Repair
                                      This specification for the HP Pavilion Wave Pavilion Wave Desktop - 600-a030na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Wave Pavilion Wave Desktop - 600-a030na boardview and Pavilion Wave Pavilion Wave Desktop - 600-a030na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
