Help Identify Parts in Asus UX363E
    Hello, does anyone know the part number of this IC in the unit I have repaired
    with a marking code:
    K4 VUE
    560308
    I think it is a dual mosfet
    The unit is Asus UX363 and no boardview available and schematic
    Re: Help Identify Parts in Asus UX363E
    PE642DT
    Datasheet here
      Originally posted by Bonzas View Post
      PE642DT
      Datasheet here
      THank you so Much sir
        Hi, does anyone can help me to identify the part number for this IC? it has "IARDM" mark on it.
        Board model: UX363EA
          Post a picture of this part. Suspecting that it will be a Silergy device and the part # is of the format IA***
            Maybe this
            https://es.aliexpress.com/item/1005006129530048.html
              Nice find! To the OP, always post a pic of the part if available. The first letter is actually ‘A' and the vertical bar prefix is to denote the orientation for mounting of the device.
              Here is a full datasheet:
              https://www.monolithicpower.com/en/d...cument_id/978/
                thank you so much!
                  Hi, I need another component from the same motherboard, is marked "62B7"
                  I would be very grateful if someone could help me
                    Hello, i need to find the component in front of the red arrow on the same motherboard, for a repair, but i dont find any shematics, can you help me ?
                      From same board they use APL6002 or UP1905AMA8
                        Thanks you so much!
                          Looks like FUSE.....
                            Hi, does anyone can help me to identify the part number for this IC? it has "LXR5" mark on it.
                              Hello again, I was able to replace the fuse that was faulty, but I am missing another component that was completely corroded, it looks like a small metal sponge and is marked U6306. I am attaching the photos below.
                                Gnd Click image for larger version
