hp elitebook 840 g2 fan always running
  • dqtech
    Badcaps
    • Jul 2018
    • 639
    • N/A
    even after shutdown, fan keep running max rpm until battery drain....also when i plugged in the charger, fan will running max rpm it self even not turn on yet...what could be the problem ya?...here i attach the video
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: hp elitebook 840 g2 fan always running
    DC-DC coverter,aka load switch, is very likely bad. Its a14 pin IC with 7 pins on each side. Replace them one by one and see if the problem goes away.There can be 2-3 such load switches.
    • dqtech
      Badcaps
      • Jul 2018
      • 639
      • N/A
      do you mean this ic sir?...L6100 3valwp / L6150 5valwp
      • dqtech
        Badcaps
        • Jul 2018
        • 639
        • N/A
        i test diode mode on 5v coil L6150 but not found any short here....any guide here?
        • Sephir0th
          • Oct 2020
          • 1289
          Load-Switch!
          If you have no idea what it is and how to search for a internal(!) shorted component, then share link to schematics, boardview or simply high quality pics of your board, please.
          FairRepair on YouTube
          • dqtech
            Badcaps
            • Jul 2018
            • 639
            • N/A
            Originally posted by Sephir0th
            Load-Switch!
            this is the schematic...only found COMET instead of CHICLET
            MOD Edit - Link to schematic https://www.badcaps.net/forum/showthread.php?t=85724
            Reminder: rules and organization of this section
            https://www.badcaps.net/forum/showthread.php?t=117483
            • Sephir0th
              • Oct 2020
              • 1289
              Q7100 for example if it exists by any chance
              • dqtech
                Badcaps
                • Jul 2018
                • 639
                • N/A
                q7100 got 5v...but q7050 only read 1.4v instead of 3v...is that right?
                • natic
                  • Sep 2018
                  • 34
                  • EU
                  Each transistor has more than one pin. If you write "q7100 got 5v" we don't know which pin exactly do you mean. So, always specify the pin number, otherwise the measurement is pointless and says nothing to us.
                  Transistors Q7100, Q7050 pin count:
                  So, please measure the voltages to ground on pins 1, 3, 4 of transistor Q7100 when the machine is turned off.
                  • dqtech
                    Badcaps
                    • Jul 2018
                    • 639
                    • N/A
                    im not doing anything on this motherboard yet, just rest for 1 night...right now when i plugged in the charger, the fan not spin anymore and no indicator light at all...like already dead...but 19v/3v/5v present...press power button no respond
                    Q7100
                    pin 1 5v
                    pin 2 5v
                    pin 3 0v
                    pin 4 0v
                    pin 5 5v
                    pin 6 5v
                    Q7050
                    pin 1 1.3v
                    pin 2 1.3v
                    pin 3 0v
                    pin 4 0v
                    pin 5 1.3v
                    pin 6 1.3v
                    i replace Q7050, now it read normally 3v on pin 1/2/5/6...0v on pin 3&4
                    • natic
                      • Sep 2018
                      • 34
                      • EU
                      i replace Q7050
                      Which transistor exactly did you use for the replacement?
                      - Measure the resistance to ground on pin 4 of transistors Q7050, Q7100.
                      • dqtech
                        Badcaps
                        • Jul 2018
                        • 639
                        • N/A
                        i replace Q7050 AO6424L with FDC653N
                        Q7050 pin 4 = 8k ohm
                        Q7100 pin 4 = 15k ohm
                        • natic
                          • Sep 2018
                          • 34
                          • EU
                          - Measure the voltages to ground on pins 14, 15, 31, 64, 74 of KBC chip.
                          - Measure the voltage to ground on pin 73 of KBC chip in the following cases:
                          a) Power button released.
                          b) Power button pressed.
                            HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook 800 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 860 16 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 860 16 inch G9 Notebook PC boardview and EliteBook 860 16 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:50 AM
                            HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook 600 Specification for Upgrade or Repair
                            This specification for the HP EliteBook EliteBook 630 13 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the EliteBook 630 13 inch G9 Notebook PC boardview and EliteBook 630 13 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                            09-07-2024, 05:20 AM
