Dell latitude 5490 la-f401p no display
    Help needed, I have 2 La-F401p both have no display. No spillage. Lcd test works fine . Both draw around 500ma then drop off to 300ma.
    I have tried various bios dumps.
    Lcd test was fine.
    No sign of spillage /blown components.
    Data pins on usb ports are not reading short to ground.
    No short on coils .
    voltage on all coils
    PCH_PLTRST# is present 3.3v
    3.3v/5v are present
    Re: Dell latitude 5490 la-f401p no display
    DRAMRST# ststus?
      1.2v
        Check for ripped components/damaged tracks near the BIOS chip and the CPU then. Normally the BIOS should initialize at this point. Maybe the firmware was not flashed in a proper way by any chance?
        FairRepair on YouTube
          Originally posted by mcplslg123 View Post
          DRAMRST# ststus?
          Hi thanks for the input. It didnt look like the bios had been worked on I think its original bios as I got in 2 with same issue.. Nothing I can see as far as missing components or track damage. Il keep working on the bios
            I HAVE ALSO SAME PIECE. DELL 5490 LA-F401P NO DISPLAY . I HAVE SAME 6 PIECES .ANY SOLUTION FOR THIS. I DID ALREADY BIOS.
              Video through hdmi port working?
                no hdmi display also not coming
                  no
                    Originally posted by Magnusa2 View Post
                    no
                    now i did one bios one time display coming . after no . i use dell og charger with battery
                      Review the power up sequence chart on sheet # 46 in the schematics. Need to review the first one where the voltage is absent that will halt the boot process.
                      Update:
                      Just read your last post. Are you using the barrel style power adapter? What are the specs? Is it the exact and recommended power adapter for this model?
                      Dell power adapters (as documented many times in this forum) use a single wire communication to determine if the power adapter is worthy enough to power these pigs of laptops.
                      Carefully measure the voltage to ground of the following points of interest:
                      NB_PSID @ PL3
                      PS_ID @ PR4
                      If the adapter ID mechanism is broken (quite common) - then the laptop will not boot as it believes the power adapter is wimpy and incapable of being used.
                        Update:
                        NB_PSID @ PL3
                        PS_ID @ PR4
                        Click image for larger version  Name:	adapter_ID_path.jpg Views:	0 Size:	423.6 KB ID:	3166595
                        THANKS FOR THE INFORMATIONS.PSID IS OKEY 3.3
                        STILL I FEEL BIOS ISSUE YOU CAN REPAIR MY BIOS
                        BECOUSE NOW I HAVE SIX MORE PIECES SAME ISSUE
                          You will have to post the bios image and request inside the dedicated BIOS forum.
                            ok
                              hii
                              i have 5490 (la-f401p) no power. 3.3v alw 5v alw not present. resistense normal. pwr src coming 12.5
                              any solutions ?
                                hii. dell 5490 (la-f401p) after logo restarting automatically. like blue screen. any solutions ?
                                  Is it stable in the BIOS screen? Tested with different RAM? Using an official power adapter?
                                    ya this one stable in BIOS screen. i use diffrent rams but same
                                      OK this one core ic problem
                                        Hello, I have Dell 5490 i7 8th generation. it gives display when i install M.2 SSD or 2.5 inch SSD. but power on and no display if i remove any installed SSD or hard drive. any solution for this problem?
                                        thankyou
