asus fx 506l problem
  • jboxer
    • Aug 2023
    • 10
    • spain
    hi can someone help me, the laptop isn't power on and the only thing that I have found is that these component has no power consumption, what component are they? and what does mean that?
  • rex98
    • Feb 2023
    • 1281
    • Mandaue CEBU, Philippines
    Re: asus fx 506l problem
    its a SMD tantalum polymer capacitor. but i don't think its the problem check for shorts and check the buck controller in that vcore section.
    • jboxer
      • Aug 2023
      • 10
      • spain
      yes you are right the problem was a short-circuit, but once I solved this ive found that there is two more short-circuit the coil that goes to the gpu power system and the coil that goes to the cpu power circuit are connected to ground but none of the components in the circuits gets hot when I inject voltage only the cpu and gpu a little bit, do you know what can be?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Do you know that cpu/gpu coils is designed to show very low resistance to GND?
        Give us exact resistance to GND on cpu and gpu coils. It may not bea short as you're assuming.
        • Sephir0th
          • Oct 2020
          • 1283
          Regarding the CPU/GPU: How much voltage did you inject and where exactly?
          FairRepair on YouTube
          • jboxer
            • Aug 2023
            • 10
            • spain
            coil 1(PL1326): 3.2 ohm
            coil 2(PL1226): 1.5 ohm
            coil 3(PL127): 1.5 ohm
            coil 4(PL128): 1.5 ohm
            coil 5(PL1025): 8.7 ohm
            coil 6(PL25): 22.1 ohm
            i disoldered PL14 coil to measure the two coil pads and see the differences
            coil pad 7(PL14): 0.9 ohm
            coil pad 8(PL14): 7.33 Kohm
            coil 9(PL13): 0.9 ohm
            coil 10(PL12): 0.9 ohm
            coil 11(PL15): 63.2 ohm
            and now talking about the tantalum polymer capacitor, those that are beside cpu receives 20v and those beside gpu 0v and this was after resolve a short-circuit before those beside cpu was receiving 0v
            thanks for all the help I appreciate the possibility to learn from everyone here.
            • jboxer
              • Aug 2023
              • 10
              • spain
              0.9 to 2v and now I know that 2v is too much, could I have burnt the cpu and gpu? how can I know it?
              • jboxer
                • Aug 2023
                • 10
                • spain
                and i inject the voltage in the pad coil that goes to cpu and gpu, the one that is 0.9 ohm in PL14 and pl1227 pad for cpu, the consumption was about 2.5 amps
                • Rajputrulers
                  • Jan 2023
                  • 6
                  • india
                  Da0p5hmb8h0 rev : H
                  Bios hhd not working
                  Last edited by SMDFlea; 09-02-2023, 02:26 AM. Reason: Bios removed,this is not the bios requests section
                  • jboxer
                    • Aug 2023
                    • 10
                    • spain
                    Re: Da0p5hmb8h0 rev : H
                    do you think? so what is the file for?
                    if its for programming bios, I don't have programmer to do it
                      • 21204
                      Reminder, rules and organization of this section
                      https://www.badcaps.net/forum/showthread.php?t=117483
                      Laptop bios requests go here -> https://www.badcaps.net/forum/forumdisplay.php?f=40
                      Read the rules before posting !!! ->
                      • arber1232
                        • Dec 2019
                        • 377
                        • Albania
                        2v i think you burn cpu and gpu
                        • jboxer
                          • Aug 2023
                          • 10
                          • spain
                          how can I truly know it, do you know some technique?
                          • arber1232
                            • Dec 2019
                            • 377
                            • Albania
                            i think the cpu takes a lot of amps, 2.5 amps is too much. but if you had a problem with the cpu or gpu, I believe that the mosfets of the cpu or gpu would be in shorts
                            • jboxer
                              • Aug 2023
                              • 10
                              • spain
                              is that posible if I inject the voltage in the pad of coil that is not connected to mosfet? see schematics and where I injected voltage, if its possible that's a hope to save the laptop
                              • lazaro.089
                                Asus Zephyrus M16 / GU603ZW problem
                                by lazaro.089
                                Full name/ Model: Asus Zephyrus M16 / GU603ZW-M16.I93070T
                                CPU: Core i9-12900H
                                Onboard 8GB DDR5 4xMT60B1G16HC-48B:A
                                Problem: This laptop was brought to the shop with the board already meddled with. Last technician (maybe without the right tools) removed an electrolytic capacitor (PCE9203) sensing resistor (PRS9801) and probably flashed both BIOS (U2802) and VBIOS(U7802).
                                The laptop's behavior is: When connected, it tries to power up. CPU powers on, and (allegedly) the power sequence finishes and goes to S0 (PLT_RST = 3.3V). It consumes 600mA, ramps up to 1.100 A and...
                                08-26-2025, 06:33 PM
                              • AtelierRepa
                                ASUS X712JA problem
                                by AtelierRepa
                                I have a problem with the bios, let me explain.
                                With BIOS 1, the pc takes +- 30 seconds to display the ASUS logo (black screen) and to boot.
                                I did a clear ME, my black screen problem for 30 seconds at boot is solved, it gives me directly the display and boots quickly.
                                My problem is that now, once the charger is plugged in and I put a slight load on the processor, it bogs down to 0.39GHz...
                                The only solution is to unplug the charger to get the cpu back up to speed. But as soon as I plug in the charger, it goes straight back down....
                                06-15-2024, 04:33 AM
                              • Dobrowol
                                Asus GA402RK keyboard and kb backlight problem
                                by Dobrowol
                                Hi. I have a problem with Asus ROG GA402RK. The keyboard suddenly stopped working along with the kb backlight. I replaced the keyboard and the ITE KBC chip and the problem is still the same. I don't see any passive elements that look damaged. Does anyone have an idea?
                                04-28-2025, 04:30 PM
                                ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook 15 Specification for Upgrade or Repair
                                This specification for the ASUS VivoBook ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD boardview and ASUS VivoBook 15 S513 FHD i5 16GB/512GB G3 SSD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                09-07-2024, 02:50 AM
                                ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook CX1 Specification for Upgrade or Repair
                                This specification for the ASUS Chromebook ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB Chromebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB boardview and ASUS Chromebook CX1100CNA-GJ0038 11" HD Celeron 4GB 64GB schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional...
