Lenovo LV315KB MB 17807-3M ,Some times no display
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 346
    • India
    Hello
    Lenovo LV315KB MB 17807-3M ,board most of the time has no display,
    when display comes also ,
    don't turn OFF with power switch pressing once(has to keep Press force OFF) .
    Starts fine pressing one.
    when no display , No power at PL4802 coil missing 00.3 m.volt
    when display comes same coil shows .929 volts
    PL4701 coil shows power .927 volts
    Tried flashing few bios ,no change.
    Please help Thanks
  • ravi_1617
    YY Solutions
    • Jan 2012
    • 346
    • India
    Re: Lenovo LV315KB MB 17807-3M ,Some times no display
    Just an update ,thought for Caps lock light (flashing) but ,as i switch on caps lock light stays on continuously
    • ravi_1617
      YY Solutions
      • Jan 2012
      • 346
      • India
      Any one please guide,
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        Remove the coil PL4802 and inject 1V on PT4801,pad1 from dc supply and then power it on with adapter. See if it works everytime.
        • ravi_1617
          YY Solutions
          • Jan 2012
          • 346
          • India
          Thanks for reply ,
          want ask what about PU4802. shall i remove this too
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            No need to remove PU4802 when coil is already removed and you're going to inject voltage on the consumer side of coil(Producer side pad of coil PL4802 is connected to PU4802)
            • ravi_1617
              YY Solutions
              • Jan 2012
              • 346
              • India
              Hi !
              Update , board don't start and stays ON,
              turns , ON & OFF repeat (As adapter turned on)
              once or twice stayed on
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Then not a problem with VGFX_Core.Look elsewhere.
                • ravi_1617
                  YY Solutions
                  • Jan 2012
                  • 346
                  • India
                  Ok Thanks Guiding
