X380 Yoga battery how to jumpstart BMS?
  • Liken
    • Jul 2023
    • 26
    • Basque Country
    Hi. Trying to recover a battery for X380 Yoga.
    Nominal Voltage is 15V but it had only 7V and doesn't charge.
    My idea is that probably this battery was without use long time and it has auto discharged. So I disassembled it, it has 4 cells li-poly 3.82V. I charged them individually and now battery has 15V, but bms board, battery controller, doesn't output power.
    With old thinkpad batteries you can restart, jumpstar the bms, joining its positive output with positive from cells. But it doesn't seem to work with thinkpad yoga batteries.
    Does anybody know how to jumpstart the BMS of new thinkpad batteries?
    This is the board and its pins:
    Output connector to laptop, 9 pins:
    + + + C D T - - -
    where C D T are comms.
    BMS connection to cells in order left to right, with names in board:
    VL First cell positive
    VG Ground, negative
    VM2 Second cell positive
    VH Third cell positive
    VM1 apparently same voltage than VM2
    VP Positive 15V
    Other contacts in board, I don't know function
    VH JP same voltage as VH
    VP JP same voltage as VP
    2nd JP same voltage as VP
  • Vesko356
    VIP Moderator
    • Aug 2018
    • 4386
    • Bulgaria 🇧🇬
    Re: X380 Yoga battery how to jumpstart BMS?
    Yes I know - you can't "jumpstart the BMS" on a modern laptop battery like it was done years ago with "old thinkpad batteries" on YouTube.
    https://www.badcaps.net/forum/showth...81#post1241581
    Become a Badcaps supporter
    Thanks to all supporters.​
    • Liken
      • Jul 2023
      • 26
      • Basque Country
      OK. I didn't know that modern batteries were so protected, even with passwords. Thank you.
      However, I have not done any cell replacement, and the bms has not lost voltage at any time while charging the cells individually. I understand that it doesn't matter, once it locks for whatever, goodbye.
        • Jul 2011
        • 6037
        This does not matter because once you have passed a certain amount of watt hours then on some BMS protection boards it locks the system out and in some cases it can not be unlocked from what I have read
        I have one question what is the voltage on each group of battery cells because if they are more than 0.050 volts from each other some BMS boards lock out because of this if this is the case you can try rebalancing the battery cells but I caution you that you need to be extremely careful about not letting the voltage to go below 2.8 volts pre battery cells because some BMS boards lock out the output voltage and will not allow it to be reset unless you remove all power from the circuit board but some of them if it has a micro controller it locks it permanently and it will useless
        One thing you can try is to bring down the voltage to about 9.0 to 9.5 and see if it will charge or not but make very sure that your battery voltage are exactly the same on each battery cell grouping if this does not work I no other suggestions for on this because I do not play with laptop battery packs because they are a pain in the a** to deal with
        The easiest way to do this is to use an automotive light bulb like a 1157 or a M16 20 or 50 watt do each group of battery cells individually and stop the discharging cycle when they reach 9.5 volts
        When you reconnect the battery pack to the laptop do not have the power supply turned on until you have the battery pack installed then hook up the power supply to the computer and see if this will reset the BMS board
        • Liken
          • Jul 2023
          • 26
          • Basque Country
          When I disassembled it the cell voltages were:
          c1: 0.41V
          c2: 1.82V
          c3: 2.47V
          c4: 1.91V
          The first one was very very low. However it was charging fine for hours with 0.5A. Then I charged the rest of them and they are balanced at 3.8V +- 0.04V tolerance.
          It seems clear that there were reasons for a BMS lock.
          Why are you talking about 9V, Is it some special voltage range? The nominal voltage of the battery is 4 x 3.8 = 15.2V
          • Liken
            • Jul 2023
            • 26
            • Basque Country
            Do you think it would be a viable idea to buy a cheap 4S BMS 20A board, 2$ in Aliexpress, and solder its connections to the existing BMS?
            It would be like a bridge VP to Out + but keeping safety. And the original BMS establishs the required comms. The question is, can the original BMS, through comms with the computer, inhibit the charge and discharge from the mainboard side?
            I use Linux and, although battery is dead for charge and discharge, I can see its voltage. And BIOS needs to acknowledge the battery to boot.
            (By the way, I have seen that the fuse of this BMS is DS5A4, I have not checked whether it is blown or not)
              Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) X Specification for Upgrade or Repair
              This specification for the Lenovo ThinkPad X380 Yoga Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the X380 Yoga boardview and X380 Yoga schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
              09-06-2024, 02:28 PM
              09-06-2024, 01:21 PM
              09-06-2024, 12:51 PM
              09-06-2024, 11:50 AM
